Post a pic of your Trans Am/Firebird!
#127
![Name: WD7A0038_zpsb99afcdd.jpg
Size: 38.5 KB](https://ls1tech.com/forums/attachments/pontiac-firebird-1967-2002/584726d1501202954-post-pic-your-trans-am-firebird-wd7a0038_zpsb99afcdd.jpg)
#136
I've had this car since May 4th 2017 and have put on 8000 kms (5000 miles). It had lowering springs on it when I got and those were the first to go - couldn't stand the ride and couldn't clear anything on the road. Much better now. Need new tires as a result - they didn't wear well with the lower springs. Love it so far, what a great grand touring car this is!
#138
#139
Your tire wear had nothing to do with the actual springs themselves or being actually lower, its all in the alignment. After changing ride height the car needs to have an alignment done, if not the tires will wear quickly and likely on the inside. With that being said hopefully you got a proper alignment done after putting oem springs back on, otherwise your tires may still wear quickly.
