Project Nova - The quest for 1000hp VS s480 l33 347
I really wanted to run inner fenders, I tried and tried but could t figure out a way to do it without crazy bends for both exhaust and cold side. This turbo is massive coming from a billet 78/75 t4.
It's the billet 80mm s480 clone from Vs racing. 5" inlet and exhaust :/
Just got off the phone with my machinist. When I dropped off my blocks for machine work, I left him an l33 block and an lm7 block, told him I wanted to use the l33 block if it's possible, if not we will go iron. He sonic checked and then bored the aluminum block. The l33 block sleeves is .100 thick at its thinnest point in the steel sleeve, not on a thrust wall towards the bottom of the sleeve, so we are going ahead with it. 347 l33.
Also ordered my Viking D/a today, 450# spring rate front coil overs
It's always interesting to see the various turbo mounting schemes used in third gen Nova's.
I had forward roll cage bars to deal with that pretty much dictated where mine went. I wasn't able to run a filter, but mine is way more race than street so I made that consolation.
I have no inner fenders either.
I'm nearing completion of installing a very large custom intercooler as the small Treadstone I had wasn't cutting it at 20 psi and I plan to turn it up. So good that you are going big from the get go there.
Keep up the good work!
#39
Thanks Rk, and looks good!
that little Honda is nasty, watched one of 1320's videos on it. CraZy and the owner seems cools as hell.
got half my hotside wrapped tonight, ran out of wrap. Practiced my tig welding tonight as I have a lot of aluminum to weld and I'm an extreme noob with aluminum tig. Dig okay, could have been worse from r sure.
#40
that looks like the Global West Coil over stuff, I'm looking at their front and rear Coil over for my 72, looking at doing a similar deal with the cast hooker manifolds, or make a log type manifold with some .120 wall stuff... Do you have a support going to the frame to help hold that Turbo? Looks like a great build, keep motivating!!!
