LS3 T56 in 1978 Firebird Restomod Questions
1. I am looking at 2 swap kits BRP and Holley. Does anyone have any experience with these especially with the T56? Do I need to do major surgery on the trans tunnel with either?
2. Drive shaft, does anyone make one for this swap or will this be a modification of the stock one? Will the stock one hold up to about 500 hp&tq?
3. What clutch slave and mounting bracket setup are people using with good streetable results?
4. AC, are people making this work with the stock parts and custom lines or is vintage air setup the way to go? Vintage air seems pricey especially if you have a factory ac car to begin with, but can make room in the budget if necessary.
5. Looking at ridetech 4kink setup. Does anyone that has this have an opinion on it? Does anyone know of a cheaper coilover setup for these cars that is a similar setup/quality?
Any help is appreciated, help with pictures is greatly appreciated. If there are any other big challenges that people have run into with this swap you think would be beneficial I am all ears.
These kits were cutting edge 7 years ago, but they are now pricey for what you get. Dirty dingo and ebay swap plates all do the same stuff now....
You will need to perform a bit of surgery on your tunnel. In my case, I cut into the cross-brace in the floor just behind the shifter hole about an inch and a half, and welded in plates to box off the void between the floor and brace. My car was originally an automatic car, and I had to massage the tunnel a bit with a BFH, and then added a 4-speed shifter hump (Year One, part # F45H).
For exhaust, I'm using Edelbrock headers (no longer produced - use Holley/Hooker conversion headers) tied to a 3" Pyoes X-pipe dual exhaust with hi-flow metal core cats and el-cheapo Summit mufflers.
I then switched to the design noted in my build thread (post #1). That too was less than ideal, having an angle around 75 degrees. Leakage occurred after a summer of very hard use. For my current setup, I did relatively major surgery on the firewall:
- Removed the e-brake entirely
- cut the firewall hole for the wiring harness/fuse block so I could relocate the block almost 2" to the left, as you are sitting in the car.
- created a combination mounting plate/firewall patch that put the clutch master up at the same level as the brake master AND provided something for the fuse block to bolt to.
- Moser makes housing ends and axles that allow you to convert over to a Ford-style bolt in axle setup while retaining stock brake mounting. if you do any appreciable amount of high-G cornering, you will appreciate the lack of pad knock-back that results from this.
- stock 1998-2002 f-body rear brakes. The original 2nd gen disc brakes absolutely suck on the track.
- True Trac diff with 3.42 gears. Works good. Kinda up in the air on longevity. I replaced a diff after one year, but the new one has held up well
- Hypercoils makes fiberglass leafs, which knocks down unsprung weight AND eliminates spring sag. They don't make "lowering" springs though, and I had to use lowering blocks.
- I also use a Fays2 Watts Link and axle pad locators from Custom Works Performance. Note that you will have exhaust clearance issues with the watts link. I have turndowns just before the rear axle.
- The front cross bolts for the leafs were relocated upward 3/4 inch by drilling new holes in the spring brackets.
- Viking DA shocks
- removed the rear sway bar.
any time. That's what this forum is for. I'm sure lots of others will provide insight as well.
For exhaust, I'm using Edelbrock headers (no longer produced - use Holley/Hooker conversion headers) tied to a 3" Pyoes X-pipe dual exhaust with hi-flow metal core cats and el-cheapo Summit mufflers.[\Quote]
Good to know about the support provided. I feel it is rare anymore that the people selling the stuff know much more than some of the people buying it. I am going to try to run some stock exhaust manifolds on this thing. I have about 4 sets here already and since they should be good for the HP needs I am looking to achieve I may try to save a few bucks here.
Do you remember what size mufflers you are using by chance?
[Quote}
I started out using the DSE plate with a RAM Master, but the angle of the master to the pedal was nearly 45 degrees (should be as close to 90 as possible) and caused enough side-load on the plunger shaft to produce a noticeable leak after just 2 days of use.
- Viking DA shocks
Another, less complicated approach may be to use a clutch master with the mounting holes to the sides, rather than top and bottom (like the one depicted in the picture below). This would move the pushrod up and to the right, putting it at the same level as the brake master. Please note: I have manual brakes / no booster. The picture shows my "Plan A" approach from a couple years ago. I'll try to get pics of my current "Plan B" setup tonight.
Also i am looking at the year one 17" snowflakes. Can I do a 17x9 front with 17x10 rear under the stock body? I am looking to run staggered 255 front and 285 rear if possible. If this can work what back spacing is needed?
I added brackets fabricated from 1.5" angle aluminum and 1.25x.24" aluminum bar to eliminate firewall flex. Both masters are Wilwood. Brake is 1" bore, clutch is 3/4" bore.
Engine wiring harness block was moved to the right (from this view) about 1.5 inches to make space for a wilwood clutch master.
This video shows my car pre-paint on the track with the big wilwood 6 pot calipers and manual brakes. Lots of speed up and slow down in a short period, from 40mph to north of 120.
