Need some exhaust advise
Old 08-25-2017, 02:32 PM
  #181
Mike ctsV's Avatar
How do i bleed this coolant? Im draining and refilling.
Old 08-25-2017, 02:52 PM
  #182
FuzzyLog1c's Avatar
Do it as shown on the right. The bolts will not loosen if you tighten them down. I don't recommend loctite or anti-seize on the threads because that area gets incredibly filthy and any gooey material there becomes filled with small rocks. In the short term, that debris makes it hard to spin the nuts off, and in the longer term, it grinds the threads down forcing you to replace the nuts and bolts.
As far as tightness goes, I've never checked, but I probably tighten them to 45-75 ft-lbs to ensure an airtight seal between the ball and socket. If you watch closely, you'll notice that there's a point where adding additional torque doesn't make the ball-and-socket mate closer together. If you massively overtorque, which I've done, you might cause the metal plates to banana a tiny little bit but it's never affected the quality of the seal.
Old 08-25-2017, 03:26 PM
  #183
Mike ctsV's Avatar
I can only get it to take 2 gallons of coolant, i thought it took 3. Im gonna let it run with the heat on and pump the upper hose while the resivor cap is off
Old 08-25-2017, 03:40 PM
  #184
BudRacing's Avatar
That's about all mine has taken. Just squeeze the upper rad hose a little and let it run while filling and it should bleed most out itself. I did it recently and only had to top off the reservoir once afterwards.
Old 08-25-2017, 03:55 PM
  #185
Mike ctsV's Avatar
Took her for a frw mile spin, it aint to loud untill about 3k, then it just sounds pretty mean, but it also stinks.
Old 08-25-2017, 04:01 PM
  #186
Mike ctsV's Avatar
Old 08-25-2017, 04:27 PM
  #187
Mike ctsV's Avatar
Thanks for all the help through this everyone
Old 08-25-2017, 04:29 PM
  #188
FuzzyLog1c's Avatar
Sweet dude! I bet you're happy that it's done! If you need cats later, I'll be getting rid of my Magnaflow catback in a few weeks when my other stuff comes in. I had 6760-FC high flow cats welded onto the Magnaflow after I couldn't take the smell anymore.
Old 08-25-2017, 05:52 PM
  #189
Mike ctsV's Avatar
Ok thanks fuzzy, ill keep u in mind
And im glad its finally done, tooke me probly 12 hours by myself, 3 days with a few hrs each day, plus a few problems, but atleast i know how to do it now lol.
But i never wanna have to go through this torture ever again.
Old 08-25-2017, 07:24 PM
  #190
Mike ctsV's Avatar
Ok i got this code twice, but the first code said the same thing but it also say low voltage or something below it, but im assuming thats the front one? I figured i would be getting the code for the rears since its catless, but the driver side is the side i didnt use the extension harness, that wouldnt have nothing to do would it?
I would swap the front to the rear, to see if that changes anything, but the plugs are different.
Old 08-26-2017, 05:25 PM
  #191
Mike ctsV's Avatar
No codes today so far, do u guys suggest running an aftermarket x pipe or is the factory resonator pretty good?
Old 08-29-2017, 01:57 AM
  #192
Vcaddy71's Avatar
Depends how loud you want it. Removing the resonator and installing an X pipe will definitely give it a more aggressive sound. Really depends what your looking for. If you are really concerned with drone, I would probably stick with a resonator.
Old 08-29-2017, 08:23 AM
  #193
Mike ctsV's Avatar
Ok cool, it sounds pretty good to me, for some reason it started to sound better as time went on. Maybe it gave it time for the new exhaust to set in? Lol idk.
But it sounds great and sounds pretty quiet under 3k rpm
Old 08-29-2017, 09:45 AM
  #194
BudRacing's Avatar
New exhaust parts sound a little "tinny" and quiet at first. Once they get a coating of carbon on them the tone and overall sound changes.
Old 08-29-2017, 10:47 AM
  #195
Mike ctsV's Avatar
Ohh i see, i thought it sounded different the 2nd day, and then the 3rd day sounded different again
Old 08-29-2017, 10:51 AM
  #196
BudRacing's Avatar
Yeah, it kinda makes all those same day before and after videos immediately after exhaust upgrades seem a little silly, doesn't it?
Quick Reply: Need some exhaust advise
