PS pump repair in PICS !
Old 11-11-2017 | 01:33 AM
sjsingle1's Avatar
bottom plate...alignment pins....shaft
Old 11-11-2017 | 01:34 AM
sjsingle1's Avatar
pressure valve line up
Old 11-11-2017 | 01:36 AM
sjsingle1's Avatar
this valve controls pressure....PSC told me they take that nut down and back it out 1/2 turn
how much in or out controls the pump pressure
I did not mess with it
Old 11-11-2017 | 01:38 AM
sjsingle1's Avatar
this is the nut that the high pressure line screws into....found sum leftover O ring from the high pressure line in it....check inside of yours if you change out the line
22mm is the nut size
worn out flat O ring !
Old 11-11-2017 | 01:39 AM
sjsingle1's Avatar
to get the retaining ring off the rotor I used the small screwdriver
Old 11-11-2017 | 01:43 AM
sjsingle1's Avatar
put the bottom plate on the shaft ...then the new rotor on top
I used assembly lube where the shaft rides on the bottom plate
to put the new retaining ring on the shaft I put the shaft in the press...press the ring down....it opens up and then use the small screwdriver to wiggle it down to the recess in the shaft
Old 11-11-2017 | 01:44 AM
sjsingle1's Avatar
Old 11-11-2017 | 01:45 AM
sjsingle1's Avatar
the empty housing...the shaft rides on a fluted bushing in the housing
used some assembly lube on the bushing
Old 11-11-2017 | 01:46 AM
sjsingle1's Avatar
sjsingle1's Avatar
Old 11-11-2017 | 01:50 AM
sjsingle1's Avatar
lining up the bottom plate ( rotor removed for clarity )
you can see how the slots in the housing and bottom plate line up with end other ( not seen so well in pics but better when you do it ) and the alignment pins keeping it all lined up
Old 11-11-2017 | 01:51 AM
sjsingle1's Avatar
outer housing lined up with the slots....( no rotor for clarity )
Old 11-11-2017 | 01:52 AM
sjsingle1's Avatar
shaft and rotor in
Old 11-11-2017 | 01:53 AM
sjsingle1's Avatar
outer housing and new vanes in
used assembly lube on the inside of the outer housing
sjsingle1's Avatar
lining up the top plate
Old 11-11-2017 | 01:54 AM
sjsingle1's Avatar
top plate and wave spring
pump body O ring in
Old 11-11-2017 | 01:56 AM
sjsingle1's Avatar
install the O ring inside the outer cover....use some vasaline on the edge of housing
using the press to compress the wave spring and insert retaining ring
sjsingle1's Avatar
ring on....using the screwdriver ...make sure its in its slot
be sure to place the open end of the retaining ring at 3 o clock or 9 o clock from the bottom....open end where the 3/32 punch goes wont get the ring off.....jus sayin
Old 11-11-2017 | 01:57 AM
  #39
sjsingle1's Avatar
Old 11-11-2017 | 01:58 AM
  #40
sjsingle1's Avatar
22mm on the nut...new O ring
Quick Reply: PS pump repair in PICS !
