From Nitrous to ProCharger F1A94
Old 01-08-2018, 09:33 AM
LS1Tech Premium Sponsor
Aaron at SDPC's Avatar
Looking forward the results Steven!
Aaron @ Scoggin Dickey Parts Center
Email:Aaron387@sdparts.com
Phone: 1-800-456-0211 Ext: 324
Old 01-13-2018, 09:22 AM
Old School Heavy
speedtigger's Avatar
Added one of these to the mix:
Old 01-13-2018, 11:24 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
Bob
Old 01-17-2018, 12:41 PM
Old School Heavy
The new supercharger camshaft is done. Going to start prepping the LSNEXT block Saturday.
Old 02-21-2018, 06:21 PM
jaywill's Avatar
nice ! can't wait 2c the out come...
Old 02-26-2018, 03:21 PM
Old School Heavy
A few pics getting ready to deburr the new Dart LS NEXT aluminum block.
Old 02-26-2018, 05:34 PM
Monte4ever's Avatar
Nice....
Old 02-26-2018, 06:26 PM
baronsmith98's Avatar
Dart doesn't deburr the blocks?
Old 02-27-2018, 09:22 AM
Old School Heavy
The block is amazing clean cast and machined. It could be run as is, but that is not how I roll.
Old 01-08-2020, 01:00 PM
Old School Heavy
Time for an update. The project is coming along nicely and is about ready to dyno. I had to abandon the intercooler as there is just no way to get it in my chassis without cutting the car all up, which I don't want to do.
Here are a few pics:
BCNUL8R (01-08-2020)
Old 01-08-2020, 03:39 PM
LS1Tech Sponsor
Looks great! Bob
Old 01-08-2020, 09:02 PM
Old School Heavy
Old 01-09-2020, 02:57 AM
47ford's Avatar
I’ve been following speed tigger builds since the sbe days and you posting in the carb section. I loved how clean the car was and the engine/trans combo was always well thought out. Best of luck on the new combo!
Old 01-09-2020, 01:40 PM
Old School Heavy
Originally Posted by Bob@BruteSpeed
Looks great! Bob
Thanx guys. This build is getting close. I am excited to make some noise!
Old 01-10-2020, 05:47 AM
forcd ind's Avatar
I was able to fit a 3" IC'er in the front of my 65 Buick, but anything thicker would have
been into serious cutting. There might have been room to stuff an air to water in there
somewhere, but never tried.
Old 01-23-2020, 09:42 AM
Old School Heavy
I fully intended to fit one in there, but then I heard so many blow through E85 success stories that I decided to keep it simple.
Old 01-23-2020, 09:45 AM
Old School Heavy
Here is the monster of a fuel pump.
P/N 11196: Brushless In-Line 5.0 Spur Gear Pump w/ Variable Speed Controller – Signature body with mounting feet.
Ground Shaking Performance – Advanced Technology
  • Supports
    • Fuel injected engines:
      up to 3400 FWHP – naturally aspirated
      up to 2600 FWHP – forced air induction
    • Carbureted engines:
      Up to 3600 FWHP – naturally aspirated
      Up to 2700 FWHP – forced air induction
  • E85 Compatible, reduce max FWHP by 30%
  • Lighter than the traditional external mount pumps.
  • Reduced current draw at higher, EFI pressures.
  • Extended service life in methanol and ethanol.
  • New integral spur-gear pumping mechanism.
  • 90-PSI continuous operating pressure and up to 150-PSI peak pressure, base plus boost.
  • Integral, external brushless controller for clean installation, cooler fuel and enhanced reliability.
  • ORB-12 inlet and ORB-10 outlet ports.
  • Requires straight 12-VDC to 16-VDC power supply.
  • Not compatible with pulse modulated systems or fuel pump speed controllers.
EFI Rated flow of 1,700 lbs./hr. @ 40 psi, 13.5 volts
Carb Rated Flow of 1,850 lbs./hr. @ 9 psi, 13.5 volts
Old 01-23-2020, 11:06 AM
ddnspider's Avatar
Thats a heck of a pump!
Quick Reply: From Nitrous to ProCharger F1A94
