Sweet Pea 1968 Chevy II Moar Door 4.8/7675/PG
#221
#222
Brand new Holley fuel regulator has a hole in the diaphragm and is leaking fuel directly into the intake through the manifold pressure line. Called Holley to order a new diaphragm and their answer was,”sorry, we don’t sell just the diaphragm, you have to buy a whole new regulator.”
Roger that, I understand. So Sweet Pea will be getting a brand new fuel pressure regulator but it won’t be a Holley.
#224
Holley products and support are horrible! I've had really good luck with this Mallory. (e85 too) Has true 1/2 inlet/return ports as well. Used 3 of them now. Never had an issue over many years. One on my rx7 is like 6 years old now.
https://www.summitracing.com/parts/maa-4305m
#226
On the bright side, once the new FPR is here, sweet Pea should start and then begins the tuning.
I’m pretty excited.
#227
Hope you get it going soon.
#235
Hope you don't have problems with the steel wheels and 1/2" studs. There was another Nova on here that was having problems with the studs sheering off.
Here's the link: https://ls1tech.com/forums/conversio...408-ls-16.html
#236
