Yella terra wipe pattern? Good or bad?
Old 03-28-2018, 01:02 PM
itsslow98's Avatar
Default Yella terra wipe pattern? Good or bad?
Ultra lites installed on mamo 220 heads(afr casting). No shims used. Input on wipe pattern and what affects shimming will have. Am I sacrificing power with them setup this way? Johnson short travel lifters and 7.500 manton 11/32 pushrods.
Old 03-28-2018, 01:29 PM
5_litre_eater's Avatar
Here is some great information for you --
https://ls1tech.com/forums/generatio...od-length.html
By the way, shimming your rockers will affect your pushrod length.
Old 03-28-2018, 02:18 PM
Darth_V8r's Avatar
hadn't seen you in a while! Good to see you again.
Old 03-28-2018, 03:45 PM
FormerVendor
pantera_efi's Avatar
Default Witness MARKS = Top TECH
Hi 98, you ARE the type of person who I respect !
Your pictures are of a fine pattern, good work.
So I OFFER "best price" to you IF your ever want to purchase a product of mine.
Lance
Old 03-28-2018, 04:36 PM
itsslow98's Avatar
thanks, I've read over that before. I'm just getting info from some people that it looks fine and others saying it needs shims for sure.
