Stalled & Cammed A4 @ 450 RWHP - Which rear axle?
I have have Speed Engineering True Duals and they go over the axle, car isn’t lowered, need something that will clear my exhaust.
between the Strange 12 bolt, MWC 9” or Fab 8.8”, which rear should I go for?
An aftermarket rear in these cars is best looked at as a buy once, cry once item. I have so many dang clearance issues with my stamped 9" that I WISH I'd gone with the MWC or Moser fab housing, but now that it's pounded the snot out of my floor and I've welded LCA brackets to it I'm married to the dang thing.
The 9" also gives you the most diversity in center sections and axles vs the 12 bolt or S60 as far as I know.
supposed to be a direct bolt in with no fab needed. I’ve never installed one by myself but I plan to do it when I get it.
Here is a break down of our housing- https://midwestchassis.com/p/fabricated-9-specs
I took it on a longer highway drive today and I am getting vibration in the drive shaft tunnel at speeds over 70 so I’m alittle concerned about that. The shop that did the install used the stock drive shaft with a different UJoint to get it to fit. Should that be okay or do I need a new drive shaft?
