Just installed heads/cam and now car is blowing smoke and won't idle
<small>[ July 09, 2002, 08:48 AM: Message edited by: Z00 ]</small>
Just hoping that it could be an easy fix. If it isn't any of those things it may be that you didn't put the gaskets on the correct sides. There is a right and left side on these cars. They will fit on both sides but there is a top and bottom to the gaskets. Did you use new bolts? They are torque to yield bolts.
Edited because I can never remember how to spell <img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" /> VACUUM.
<small>[ July 04, 2002, 01:16 PM: Message edited by: CRASH 02 ]</small>
<strong>A couple friends and I installed heads/cam on my car this weekend. We had to use the regular valves from my old heads as we didn't have my other valves yet due to an error. Anyway, now my car is blowing smoke that smells like coolant and is overheating. It also won't idle at all which it would do earlier. Any ideas? I used new gaskets and the such.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You used your old valves?
<img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" />
AgaveCorvette--------> <img border="0" alt="[hail]" title="" src="graemlins/gr_hail.gif" /> to me--- <img border="0" alt="[devil]" title="" src="graemlins/gr_devil.gif" />
I know it's not spilled coolant in the headers because it just started doing it and I've put probably 100 miles on it so far. It would have done that before hand if that was the problem.
I checked my coolant today and it's not very low, could use a little but not too much so I doubt that's the problem as well.
I have the 227/224 tr cam. It would idle before yesterday so I doubt if it's a vacuum line as well.
As Alex said, we lapped my valves but that might still be the problem. I know I'll probably have to take the heads off but I'm just seeing what everyone thinks the problem could be first.
One thing I would check when I had the heads of is to make sure they didnt make the chambers to large.if the are to large the metal ring on the gasket will overlap into the chamber and could get burnt out very easy.thus causing a blown head gasket in such a shot time.
<small>[ July 04, 2002, 02:49 PM: Message edited by: H82BBad ]</small>
What's up Mr. Bird? <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Matt
<small>[ July 04, 2002, 02:55 PM: Message edited by: Sporadic ]</small>
This really sucks Allen. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Alex and I will do a compression check on it and go from there.
<small>[ July 04, 2002, 06:01 PM: Message edited by: Z00 ]</small>
you may be able to just pull one head off.
Let me know how it turns out, and if you have to get another set of heads, I will be glad to do them free.
Gasket Comparison
https://ls1tech.com/ubb/ultimatebb.p...=005480#000002
