Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
The 20 second valve spring removal!
Old Nov 20, 2003 | 06:54 PM
Scalpel's Avatar
Default The 20 second valve spring removal!
Well, got Larry's tool and have put it to use. The video you're about to see is of the removal of a CC 918 w/Ti retainer. The total time to compress the spring and remove the locks was right at 19 seconds flat This tool is the BEST I have used and I have changed a LOT of valvesprings. It's only $30 shipped, too!
Comes with threaded rod (high tensile strength), Grade 8 bolt, washer and tool. Here ya' go: Valve Spring Removal
Old Nov 20, 2003 | 07:23 PM
quickWS6's Avatar
Where can we get one of those at?
Old Nov 20, 2003 | 07:30 PM
Scalpel's Avatar
Pick one up here:
https://ls1tech.com/forums/tools-fabrication/95463-anyone-needing-valve-spring-tool.html
Old Nov 20, 2003 | 08:21 PM
Tally TransAm's Avatar
or you could save the money and make your own for free in 10 minutes
Old Nov 20, 2003 | 09:13 PM
Scalpel's Avatar
It's not totally free, gotta buy the metal and cutting materials which I lack so I spent the difference it would have cost me and got one packaged and ready to go
Old Nov 20, 2003 | 09:38 PM
BergerMan's Avatar
The tool seems to work ok, but I don't like the idea of NOT pushing straight down on the retainer. Its a good way to shoot a keeper somewhere where you can't find it.
Old Nov 20, 2003 | 09:43 PM
Z06PSI's Avatar
Great tool.... changed all of my springs by myself in 2 hours....had to replace the nut though.... good stuff..
PS. It installed my Dual springs with no problems.....
Old Nov 20, 2003 | 09:45 PM
Larry's Avatar
You are pretty fast Levi. Glad you like the tool.
If Tally TransAm can make this tool in 10 minutes I sure would like to see him at work. It takes more time than that to drive over and buy the material before you have even cut metal. You have to buy a 3' bar. Now to find the stud. They come from a fastener supplier and a minimum is required. We are already way past our 10 minutes that Tally can make it. You have spent more than two hours just rounding up the materials and haven't even cut metal yet.
In my opinion my tool looks a little more professional than Tally's. I'm sure his works but you can't market the quality he is showing in that pic.
Old Nov 20, 2003 | 11:12 PM
GrannySShifting's Avatar
if i wanted a few can i get a break? got a shop in Md we coudl use some email me at jeff@fbodycentral.com
Old Nov 21, 2003 | 07:45 AM
DV8's Avatar
DV8
Larry,
That looks like a great tool. Maybe one of these days I'll stop by and pick one up since you aren't too far away from me
I wonder how fast it would be with power tools?
Old Nov 21, 2003 | 08:16 AM
i rode my bike over to a welding shop by my house and said hey, do you have a little piece of steel i can have about this big. 99% of the metal places out there will give you a 3"x1.5" piece of steel they could probably find on the floor, this guy gave me two feet
theres the material, FREE
i used a cutoff wheel (could use a sazzall, band saw, whatever) and cut five slots where the U is and broke of the pieces with a pair of pliers, theres about 7 minutes
drill a hole, takes maybe 1
grind down rough edges, 1-2 minutes
there 10 minutes
and you dont need a stud and nut, yes its nice, but ive done four springs swaps on my car and 3 on friends using the rocker arm bolts with not a single problem
i didnt say you could aquire all the materials in 10 minutes, i said you could make it in ten minutes.
who cares what it looked like, only that it works. like i said i wasnt trying to market it or make any money, just help out people that wanted a cheap spring compressor. if people want to buy yours more power to you, personally i would rather use my hands and make one for free, than pay someone to do it for me.
could i also ask you where you got the dimensions for your tool, did you measure them yourself or find them online
Old Nov 21, 2003 | 10:29 AM
dragonZ28's Avatar
FormerVendor
I wonder who that total badass in the video is. Whoever it may be, I hear he is the shizzy. .
Old Nov 21, 2003 | 10:38 AM
Nine Ball's Avatar
LS1Tech Co-Founder
I have one also, and the quality of it is sweet! I like the threaded stud it comes with.
