SonofaBish's Twin Turbo Trans Am results
not spraying meth....that's in my future plans for it...
when we were on teh street, taking some logs and making sure that the A/F was fine, he told me that the A/F was staying fine... i was driving, not paying attention to the guage... but the tuner told me that it was fine... .
you need more cubes to run those numbers safely on pump gas alone, unfortunately you cant just boost it as hard as you want because 'its supposed to run only 93'
i would never run mine over 14# on 93 only and i have a 6.0 it doesnt take many engine rebuilds to learn that lesson
reguardless though when there is tuning being done that means that at some point the tune is not perfect.. and you beating on it at that level while it is not perfect has potential for problems.. which is why it is a good idea to throw some octane at it.
when head gaskets lift because of horsepower, they just move water into the overflow along with some exhaust into the cooling system. when you tear up a gasket from detonation, lots of other stuff happens like what you describe.. white smoke
theory 2 is that it somehow managed to NOT detonate, but moved a lot of exhaust into the cooling system and moved a bunch of water into the overflow.. so while you were riding around on your way home talking on the phone... your car was overheating
either way, with the prayful assumption that nothing happened to the motor, i'm going to order a meth kit and put it on to make sure i'm staying safe at that power level
I will change the oil as soon as i get an opportunity to see if anything is in it
I set out wanting to have an overall street monster, that was a total blast to run around... It was built, made my original goal, and i'm happy with that.. unfortuantely something went wrong and blew a head gasket (hopefully thats all)... live and learn -
As far as traction, i didnt get a chance to get on it at all in 1st gear, but WOT in second gear, even as hard as it hits, it has no traction issues at all, and that's even with the 50* temps outside ... maybe that's b/c of brand new MT's, and i believe that the 3:08's in the rear are really helping it to hook up...
From all i had seen on here, it seemed like 700whp on 93 pump was defintely do-able and a lot had done it.... Now i've apparently had a taste of a bit of bad luck, so i'm asking, is it safe to do it with Meth injection? I'm imagining so, but i want to be sure that the guys that have been there, and done it, agree and say that its definitely safe to do it.... I have no problem pulling the car back to 650 or further, if that little bit of power is going to save me a pile of hassle down the road a ways.... but if the Meth makes the car able to SAFELY make that horsepower, then i see why not stick with my original goal of 700...
if you know you will never ever ever turn it up and always always spray x amount of meth, you could figure it out
for example i spray about 100#/hr of meth and when i do i let bs3 pull out 15% of my fueling.. one could say i could reduce my fuel system capacity by 15% and be ok.
you CAN get 900rw if you spray enough meth on top of 60# injectors sure
