414 stroker!!!
414 stroker!!!
Price: $7200
Location (State): IA
Item Condition: Used
LS Engine?: Fits LS Engine
6.0 lq9
bored to a 414 stroker
cam trick flow
TRICK FLOW DURATION CAMING TIMING @.050 238/242 LIFT:.595 WITH 112 LSA
HAND PORTED LS3 HEADS NOT SHAVED MAX VALVE LIFT .675 LS3 ROCKERS WITH TRINUIM UPGRADE
dual valve springs
ls7 lifters
ls3 intake
102mm throttle body
Bosch Fuel Injector 57 lbs/hr 598 cc/min High Z USCAR EV6 Ecotech LS2
10.5mm race wires
melling high volume oil pump
double roller timing chain
texas speed chromemoly pushrods
Eagle crank and rods Forged
built for a nitrious motor
comes with wiring harness and ECU plug and play all tuned
The motor still in the car would like to take a person for a ride to hear it run then pull it. Best way to reach me is call 319 929 4869 I can send video or just pictures if you need. Thanks
