Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
T56-M6 Harness-Magnafuel-Complete Part Out
Old 01-06-2018, 10:39 AM
ChevyCamino79's Avatar
Default T56-M6 Harness-Magnafuel-Complete Part Out
Price: $123456
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): NY
Item Condition: Used
LS Engine?: Fits LS Engine
Most of the parts have been sold off of the car with the exception of a few. I have sold a lot of parts to Tech members and none of them have been disappointed, see sold list below. The parts are all lite-used at best and in absolutely great condition.
Motor
5.3 with hand ported 243 heads (gen vi - LY5) 38k mile (2k since mods) pulled from an 09’ Silverado. ARP head studs, ARP rod bolts, stock truck accessories, LS9 head gaskets, Dual valve springs, Speed inc TU1.5 cam, performance products intake, LQ9 pan, vacuum canister, LS2 style coils, Katech timing chain, melling oil pump, LS7 lifters, LS2 trays, Moroso wires. $4,000
4L80E crossmember $100
Fuel
17 gallon fuel cell with working sending unit. Fuel feed/supply fittings added to bottom of tank. Had this mounted in stock location with slight mods, used stock filler neck (P/N RCI-2172AD/RCI-7515A) - $150 this is the only item that I will not ship
Magnafuel 625 Pump - $300
Brakes
SLP Line Lock Solenoid $40
Turbo Misc
Innovate LC-1 Wide Band O2 with Turbo Timer (P/N 3833) $80
Body/Misc Parts
Monsoon Radio (Pontiac) - $25
150mph White Faced Cluster (122k Odometer) $40
Guages – 2 1/16” Autometer Phantom
Water Temp $30 (electric)
Boost $30 (mechanical)
Fuel Pressure $30 (mechanical)
Fuel Level $30 (electric)
Oil Temp $30 (electric)
(3) Gauge “A” Pillar Pod $20
2 1/16” AC vent gauge adapter $10 each or 3 for 20
SOLD PARTS
Stock F-Body M-6 Petals and Crossmember - SOLD
Fuel Rails with fitting Sold
aeromotive boost reference regulator with lines and fittings Sold
Braided feed and return lines w/ (2) inline filters Sold
80# Injectors Sold
M6 stock f-body harness (un-cut) Sold
Lingenfelter TRG-002 58x-24x conversion box Sold
Quick Time Steel Bellhousing (C191LS) Sold
T-56 Mag 2.97 w/hydraulics (BA76-2.97) Sold
168T Billet Flywheel -Sold
McLeod 26T RST clutch -Sold
Kore-3 Front Brake Kit (P/N 6LE-218) Sold
Rear - Dana S-60 Sold
Turbo Kit - sold
Turbonetics (F168/.95ar) 76 mm ball bearing T-4 turbo with Full stainless hot side with fender exit down pipe. Fully tig'd and wrapped, v-banded, RG-45 waste gate and blow off valve included. Retains A/C in stock location manifolds included, 4" cold side with Treadstone intercooler.
Quarter Stick w/cable sold
Turbosmart Dual Boost Controller (TS-0105-1002) Sold
Spoiler (non-OEM) sold
CME Valance sold
Griffin radiator w/ dual puller fans (P/N GRI-1-25272/SUM-G4850) sold
Spohn torque arm and tubular bracket with drive shaft loop (P/N 114-102) Del-Sphere Pivot, Dana 60 mount sold
QA1 coil overs - Fronts (Single Adjustable spring 300# P/N VAR8612F-834) sold
QA1 coil overs - Rear (Dual Adjustable 150# springs P/N 122-RCK-52329) sold
UMI Tubular K-Member (P/N UMI2320) - sold
UMI Lower Control Arms Adjustable (P/N UMI2300) sold
UMI Upper Control Arms (P/N 2311) sold
Spohn Rear Lower Control Arms Adjustable sold
Inbox or text for more info, everything is negotiable, buyer pays shipping and PayPall fees if applicable. Parts are located in Oakdale NY - 11769
631-338-3055
Attached Thumbnails T56-M6 Harness-Magnafuel-Complete Part Out-camaro-2-.jpg   T56-M6 Harness-Magnafuel-Complete Part Out-camaro-3-.jpg   T56-M6 Harness-Magnafuel-Complete Part Out-cluster-1-.jpg   T56-M6 Harness-Magnafuel-Complete Part Out-cluster-2-.jpg   T56-M6 Harness-Magnafuel-Complete Part Out-fc-1-.jpg
T56-M6 Harness-Magnafuel-Complete Part Out-fc-2-.jpg   T56-M6 Harness-Magnafuel-Complete Part Out-radio-1-.jpg   T56-M6 Harness-Magnafuel-Complete Part Out-img_5621.jpg   T56-M6 Harness-Magnafuel-Complete Part Out-img_5624.jpg   T56-M6 Harness-Magnafuel-Complete Part Out-img_5638.jpg
T56-M6 Harness-Magnafuel-Complete Part Out-img_5639.jpg   T56-M6 Harness-Magnafuel-Complete Part Out-img_5640.jpg   T56-M6 Harness-Magnafuel-Complete Part Out-img_5643.jpg   T56-M6 Harness-Magnafuel-Complete Part Out-img_5645.jpg   T56-M6 Harness-Magnafuel-Complete Part Out-img_5651.jpg
T56-M6 Harness-Magnafuel-Complete Part Out-img_5746.jpg   T56-M6 Harness-Magnafuel-Complete Part Out-img_5755.jpg   T56-M6 Harness-Magnafuel-Complete Part Out-img_5756.jpg   T56-M6 Harness-Magnafuel-Complete Part Out-img_5834.jpg   T56-M6 Harness-Magnafuel-Complete Part Out-img_5835.jpg
T56-M6 Harness-Magnafuel-Complete Part Out-img_5836.jpg   T56-M6 Harness-Magnafuel-Complete Part Out-img_5837.jpg   T56-M6 Harness-Magnafuel-Complete Part Out-img_5838.jpg   T56-M6 Harness-Magnafuel-Complete Part Out-guages-1-.png   T56-M6 Harness-Magnafuel-Complete Part Out-guages-2-.png
T56-M6 Harness-Magnafuel-Complete Part Out-wideband-1-.png   T56-M6 Harness-Magnafuel-Complete Part Out-wideband-2-.png   T56-M6 Harness-Magnafuel-Complete Part Out-wideband-3-.png
Last edited by ChevyCamino79; 09-16-2018 at 08:57 AM. Reason: Add T-56 Magnum for sale
Old 01-06-2018, 11:43 AM
allblackedout5's Avatar
Pm sent... interested in a couple things.
Old 01-06-2018, 04:29 PM
Shaarky's Avatar
Pics of the rear qa1 coil overs 4084299409
Old 01-06-2018, 04:47 PM
Surewhynot's Avatar
I sent you a text
Old 01-07-2018, 05:48 AM
All messages responded to, not looking to break down the motor at this time would like to sell complete intake to pan. TTT
Old 01-07-2018, 06:18 PM
cancam99ss's Avatar
LS1Tech 10 Year
text sent
Old 01-08-2018, 10:14 AM
Sale pending on motor package and k-member, maybe the turbo package.
The car is snowed in at the moment so if I owe you pictures of any items I apologize. I will get them as soon as there is a break in the weather.
Old 01-12-2018, 09:54 PM
duggravs's Avatar
Pm sent......
Old 01-13-2018, 09:12 AM
All PMs and text replied to. Turbo kit still available. If I don't have the larger items sold by the time I get back into town on the 24th I will start shipping items. Thanks for all of the interest, enjoy your weekend.
Old 01-14-2018, 11:00 PM
davidclapp's Avatar
Spohn torque arm and tubular bracket with drive shaft loop $200
What Trans rear is this for?
Old 01-14-2018, 11:41 PM
phenixws6's Avatar
Interested in the turbo kit
Old 01-15-2018, 03:21 AM
Default Torque Arm
Rear is a Dana 60I have had a t56 and 4l80 in the car with this bracket.
Old 01-15-2018, 03:26 AM
Default Turbo kit
Sounds good, what else can I tell you about it?
Old 01-15-2018, 11:24 AM
Chantro's Avatar
Have the 243 heads sold?
Old 01-15-2018, 12:29 PM
Sorry, am not parting out the motor at this time.
Old 01-15-2018, 05:04 PM
zmracing's Avatar
PM sent about shifter
Old 01-18-2018, 02:28 PM
Reduced price of car complete, would like to sell it whole but if it doesn't sell by next week I will split and ship any and everything.
I have a line for the coil overs f/r, the cross member with control arm and spoiler if I don't sell the car complete. make some offers, I would like to think I am very reasonable.
Thanks for looking
Old 01-20-2018, 10:52 AM
Motor back up, still not looking to part it out though, ... might consider short or long block.
Old 01-26-2018, 09:52 PM
Sorry for the delay, busy with work. Updated list with part numbers.
The Coil Overs and K-member are spoken for with a few people in line for them if local sale falls through. Car is apart, will upload more pics tomorrow.
Looking for offers on turbo kit and complete motor: Make offers, I am very reasonable. Thank for all of the interest.
Old 01-28-2018, 06:22 PM
Updated part availability and prices
Sale pending on:
Fast 102
Throttle Body
Front Coil Overs
Rear Coil Overs
K-Member
Upper Control Arms
Lower Control Arms
Torque Arm Bar and Bracket
Wide Band
Radiator and fans
Make Best offer on Rear, Turbo Kit and C5 brakes
Quick Reply: T56-M6 Harness-Magnafuel-Complete Part Out
