Procharger D1SC kit with front mount intercooler (9 second setup)
Category: Engine - Power Adders
Price: $5500
Location (State): NY
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
-ATI Procharger D1SC with EPP front mount intercooler
- 8-rib setup; includes 7.65" crank pulley and 3.55 blower pulley.
-Aster J - bracket is an upgrade from the procharger.
Will include instructions for install.
-Truck Blower hat with 4" K&N filter (This is a upgrade)
-Tial 50mm Bypass valve (This is a upgrade)
-Spal 16" fan and Procharger fan shroud. (Fan is a upgrade)
-All piping with all clamps
- 8-rib belts for use with 3.55" pulley
-Vaccuum manifold
-Autometer boost gauge
-1 bottle of Procharger oil
-80# injector
-2 bar gm map sensor
The only thing you will need to bolt this on your car and go is your fuel pump. As previously stated, I did not need the relocation brackets for air pump and the cruise control. If you need them, the relocation brackets are readily available from some of the board sponsors.
This kit has about 2500 miles on it, oil was changed once. Payed $6900 for the kit new plus the extras.
Asking $5500 This would cost over $8000 with everything listed.
Paypal is available 3% surcharge.
Serious only call Jason at 716-535-0476
http://www.youtube.com/watch?v=DyIswZgHmKA
Ran 9.88 @ 134 With a 1.31 60 ft.
ATI Procharger D1SC kit with Epp front mount intercooler and 8 rib setup. This kit is complete with the exception of the relocation brackets for the air pump, and cruise control box, didn't need it. I have every clamp, nut, and bolt you need to install this kit in its entirety. Here's the breakdown:
- 8-rib setup; includes 7.65" crank pulley and 3.55 blower pulley, as well as a blower brace. Will include instructions for install.
-Procharger fan shroud with 16" fan
-2 8-rib belts for use with 3.55" pulley
-Vaccuum manifold
-1 bottles of Procharger oil
-80# injector
This kit has less than 1000 miles on it oil was changed once. This was installed last winter so it was only used this past summer.This kit is installed on a 2002 Camaro. Payed $6900 for the kit new plus the extras.
$5200 shipped. Paypal is available 3% surcharge.
-Vaccuum manifold
-80# injector
