My project, a 1968 pontiac catalina with a C5R 427
Old 03-24-2011 | 05:43 PM
Tramminc's Avatar
Default My project, a 1968 pontiac catalina with a C5R 427
C5R 427 block
Callies dragon slayer 4.0" crank
Comp star rods (made by Callies)
Weseco pistons -8 cc
ETP 225cc heads , ported to 232cc by WCCH 2.12 intake 1,94 exhaust valves, .700" lift valve springs
Cam 255/257 .624/.624 lift on 111 +4
Super Victor intake
105mm TB with custom elbow
Stock rockers
LS7 lifters
ported oil pump
dual roller timing chain
Fuel
255L intank pump
60lb injectors
custome feed/return lines with regulator
Tranny
FLT level 6 with hardened input/output shafts
Yank SS3600 stall
SFI flexplate
Rear
3.55 gears with 30 spline axles,heavy duty posi unit
Old 03-24-2011 | 05:53 PM
the_merv's Avatar
Nice..how much power you looking to make?
4L60E or an 80?
Old 03-24-2011 | 06:02 PM
darksider's Avatar
Great build. I've been thinking of putiing in an LS based engine in my 68 Bonneville. Maybe after the GTO is done, and I save some more money.
Thanks for the pics.
Old 03-24-2011 | 06:28 PM
Tramminc's Avatar
4L60E or an 80?
Motor was removed from a 2000 trans am built by slowhawkprefromance running in the 10 second bracket 373 gears.
Old 03-24-2011 | 08:04 PM
Tramminc's Avatar
4l60E
Old 03-24-2011 | 08:16 PM
Tramminc's Avatar
drivers side clearance
passenger side clearance
looking under the nose
12.25 inch wilwood kit with e-brake, I'm still altering it to work, but it does fit.
waiting for spacers to gap the rotors from the caliber bracket
Old 03-24-2011 | 08:23 PM
Irish350's Avatar
so much room in there
next to the 7 liter
Old 03-24-2011 | 08:30 PM
Tramminc's Avatar
Man I want this thing running NOW I've been on the job due to sciatica nerve damage in my back, cars been hanging for 4 months. on a good note the lift hasn't flexed 1 bit, I measured the towers from the wall on both sides and the measurements are the same.
P.S.
Old 03-24-2011 | 08:53 PM
darksider's Avatar
Good news on the lift anyway, that's a hell of a lot of weight on it.
Old 03-24-2011 | 09:01 PM
Tramminc's Avatar
OK here's the story, I've had this car for 16 years, I remodeled it once before by rebuilding and modding the 400 motor. I purchased my vette 6.5 years ago, this car became a bald headed step child, and was forced to sit outside the whole time. I couldn't bring myself to sell it, this has to be 1 of pontiac's best body styles. Many times I had the needle bury past 120mph and it was still pulling. when cruising people move out the way because they don't know what it is..
In 1968 power at crank was 340 hp and 430 torque. all the old pontiac had big torque to move those cars. Weight when new 3943 pounds, so far with the motor and tranny swap it lost 200 lbs. It will be on more of a diet.
Old 03-24-2011 | 09:04 PM
Tramminc's Avatar
I do plan on standing up 2 x 4's under each arms for the long term.
Old 03-24-2011 | 10:20 PM
darksider's Avatar
Here's my Bonny.
Old 03-25-2011 | 08:12 AM
Tramminc's Avatar
Here's my Bonny.
Yes both are the same car, we can share some secrets to make our build fast and better for each of us.
The rear 12.25 disc brake with e-brake came from http://www.hotrodsusa.com/store/dpsrear_pbrake.html they work with wilwood to build it to fit the car. also came with free front to rear e-brake cables.
Some of these may help you. High light the lines one at a time and open a new search window, they were copied from my office firefox bookmarks folder.
Mod Motor Tech Forums
Chevy Chevy Engine Oil Pan, LS1, LS2, LS3 & LS6 Engines, Aluminum, 1955-1972 - Eckler's Classic Chevy Parts
Pontiac Parts and Pontiac Auto Parts - California Pontiac Restoration
58 59 60 61 62 63 64 Chevy Impala Brake Parts Product Detail
Corvette rotors for big disc cars. - Canadian Poncho
Disc brake conversion kit for my 67. - Canadian Poncho
Chevrolet Impala FullSize Cars 1958 - 1996
Wilwood 140-9053-D Wilwood Dynalite Big Brake Front Hub Kits
1LE Conversion Tech Article - NastyZ28.com
Car-Part.com--Used Auto Parts Market
Zero Offset™ Brake Kits
pontiac b body brake conversion - Google Search
« Hotrod & Restoration
64-72 A Body 4 Wheel Power Disc Brake Conversion Kit : eBay Motors (item 290467322544 end time Oct-16-10 12:22:16 PDT)
Scarebird Classic Brakes LLC
Cheapest Parts Big Front Brakes
b-body spindle swap for 12" ft brakes [Archive] - NastyZ28.com
Disc brake conversion kit chevy Automotive Parts at bizrate - Shop online for Automotive. Compare Prices and Read Consumer Reviews
Disc Brake 65 - 68 Chevy
Guide To A-Body Disc Brake Swaps- Car Craft Magazine
B-body disc - Shop sales, stores & prices at TheFind.com
HP Mopar B-Body & E-Body Complete Stock Height Disc Brake Kit at Carolina Classic Trucks
ECI Disc Brake Conversion Kits - Chrysler Products
Installation Instructions for Classic Chevy,GMC and Ford cars and trucks. Classic Performance
B-Body Dual Diaphram Brake Booster Upgrade - MonteCarloSS.com Message Board
GM B platform - Wikipedia, the free encyclopedia
Foose Design
Driveshaft Specialist Inc
Schott Wheels - Modular Series
1969 Pontiac Catalina Body Parts -
Pirate Jack Hotrod & Restoration Auto Parts
GM Rear Disc Brake Conversion 10 & 12 Bolt, E-Brake - Madras
Cross Canada Collision Parts Specialists - Home
1968 Pontiac Catalina Body Parts - Brakes, Suspension & Steering
YouTube - 1968 Pontiac Catalina
Digital Instrument systems
5 Gauge Universal Street Rod Panel
Classical Pontiac
Master Power Brakes - Product Search Results
Hotchkis Sport Suspension - 67-70 Chevrolet B-Body Sport Sway Bars :: Sway Bars :: Sway Bar Sets
Old Air Products
InterNetrader Catalina Magazine, 1966 Pontiac Catalina, 1962 1968 1959 1973 1960 1970 1975 1963 1969 1972 1967 1964 Catalina 2+2, 1965 1956
Adrienne Janic's 1968 Pontiac Firebird - Popular Hot Rodding Magazine
Auto Parts Firm
Suspension Systems :: Vehicle Packages :: 1965-70 Pontiac Full Size - Level 1 - RideTech.com - Air Suspension Specialist
Suspension Systems
Fatman Fabrications
Disc Brake Conversion basics [Archive] - Chevelle Tech
Ames Performance Engineering, Classic GTO Parts, Firebird Parts, and Full Size Pontiac restoration parts.
1968 PONTIAC CATALINA Information Specifications Resources Pictures
Muscle Car Parts, Pontiac GTO Parts, NOS GM Auto Part, Trans AM, Oldsmobile 442 Cutlass, Buick GS Skylark, Firebird, Bonneville, Grand Prix, Catalina, Olds 88 98, Starfire, Chroming, Polishing, Welding, Stainless Steel Straightening, Aluminum, Restoration Services, Vintage, Classic Cars, Rust Free Sheet metal, Salvages, Dealers, Reproduction, Weatherstrips, Seals, Chrome Shops Plating
1968 PONTIAC CATALINA Engine Parts
68 Lemans LS1 T56 swap - Page 3 - LS1TECH
YouTube - 1968 Pontiac Catalina Drum To Disc Brake Conversion Part 01
YouTube - Rear Disc Brakes - Part 1
YouTube - 1968 Pontiac Catalina Drum To Disc Brake Conversion Part 03
1968 pontiac catalina - Shop sales, stores & prices at TheFind.com
1968 Pontiac Catalina body parts at wholesale price | Buy car/truck parts online & save!
Super Bright LEDs - Brake Light, Turn Light and Tail Light Bulbs
PartsTrain.com - Hard to Find Auto Parts and Truck Parts - Ball Joint - For 1968 Pontiac Catalina Ventura 8 Cyl 6.6L
Babs, short for Big A** Bertha: Frank's 1968 Pontiac Catalina 1968 Pontiac Catalina - Forked River, NJ
Search Results - Hotchkis Sport Suspension
Pontiac Catalina Tie Rod - Tie Rod - Partstrain.com
PONTIAC ZONE TECH FORUMS - Powered by vBulletin
A parts catalog of GLOBAL WEST SUSPENSION suspension components for American Muscle cars.
Ram Air Box
Spectre Performance - Official Site
Edelbrock 38793 - Edelbrock Competition 4-Barrel Throttle Bodies - Application - SummitRacing.com
Bi-xenon: FX-R - HID Projectors from The Retrofit Source LLC
Bi-xenon Morimoto Mini Stage III Kit (D2S) - Complete Kits from The Retrofit Source LLC
1968 full size b-body Pontiacs photo gallery at ClassicPontiacs.com
Eagle Mat & Floor Products Providing Service World Wide Since 1983
Old 03-25-2011 | 12:07 PM
darksider's Avatar
Wow, thanks for the info. I'll look them up as time allows.
Old 03-25-2011 | 12:31 PM
the_merv's Avatar
Ya that might take a min..
Old 03-25-2011 | 02:24 PM
Tramminc's Avatar
I'm installing these on the car where the low beams are, the high beam lamp are being removed to insert funnels tubes to force are like the vararam induction unit to the TB.
http://www.theretrofitsource.com/pro...roducts_id=101
Old 03-25-2011 | 05:45 PM
bonecrrusher's Avatar
OH Snap... Max lift... how high is your ceiling?
Whats your opinion of that lift? That list is on my consideration list...
Old 03-25-2011 | 10:27 PM
Tramminc's Avatar
Ceiling is 90 inch high, I can sit under the catalina, on my rolling bench and work, I had to drill another set of holes on the sides of the towers to slide the bars through to land the car on. The vette gets lifted to the top factory holes.
Picks this 4000 pound car at the same speed as a empty lift, down speed is smooth.
Old 03-29-2011 | 10:03 AM
Tramminc's Avatar
Default Disc brake are done
All I have to do now is run the brake lines.
Old 03-29-2011 | 10:12 AM
Tramminc's Avatar
Before I put in place I have to fix a small hole on the trunk where the external fuel pump was mounted, and also make brackets to mount the new 1 inch solid sway bar. The car never had rear bars, only a wimpy 3/4 front bar, now it has a 1.19 inch front solid bar.
Quick Reply: My project, a 1968 pontiac catalina with a C5R 427
