Ltx...Lsx blow out
Category: Engine - Intake/Fuel
Price: $1
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette
Location (State): IL
Item Condition: Used
Engine: LS1/LS6, LT1/LT4
LS Engine?: Fits LS Engine
93 timing cover $45 shipped
92-94 timing chain with gears less than 6k miles on em. $50 shipped
93-97 stock oil pan x4 painted black with rails $45 shipped
94-97 stock plastic fuel lines in engine bay from fuel tank...2 sets of these $65 shipped ea set
96-97 crank sensors that bolt in timing cover x2 $30 ea s/h
stock crank pulley x2 $25 s/h
power steering pump x2 $40 ea shipped
stock upper and lower A arms, Both $80 shipped
Stock master cylinder $25 s/h x2
brake booster $40 s/h x2
abs block $40 s/h
steering shaft x2 $35 s/h
washer resevoir x2 $25 s/h
Lifter cradle x3 $25 s/h
distributor shaft x2 $25 s/h
Stock heads, 2 sets with valves only, NO springs $200 shipped ea pair
coolant crossover tube $35 shipped
t top weather stripping both sides...$40 shipped ea
pedal assy x2 for a4 cars... $35 shipped
t top holders in the trunk....$45 shipped
4 channel abs sensor fronts and rears, wiring only!!!! $50 shipped for all of it.
or $15 ea shipped front harness and $25 rear shipped
93-97 water pump with 160 t stat in housing $45 shipped
k&n air filter for 93-97 cai $30 shipped
stock rocker arms, complete 35 shipped
93-02 firebird dash a/c vents x2 $20 shipped ea.
93-97 headlamp x2 $20 shipped ea
93-97 rt front turn signal amber lense for firebird $25 s/h
93-02 firebird 3rd brake light $20 sh
93-97 firebird hvac controls $25 sh
93-97 firebird radio, hvac plate that covers both of them $30 sh
seat belt guides, dark grey mint $40 shipped
Salad shooter style or impala chevy center caps $45 s/h
93-97 egr valve less than 2500 miles $15 shipped
93-97 rear main seal adapter with gasket affixed. $20 shipped
93-97 rearview mirror with working lights I dont know if this will fit 98-02
check before purchasing. $25 shipped
93-97 firebird,t.a headliner mirror cover $15 shipped
93-02 firebird,t.a steering wheel great condition w/o airbag $50 shipped
2 airbags for steering wheel, 1 for camaro and other for firebird $40 shipped ea. dark gray color not ebony
camaro door bezel rt side black color $20 s/h
stock shifter x2 $35sh
rear bumper camaro sidemarkers $30 s/h
glovebox ebony $45 s/h
rearview mirror $25 shipped
rocker panel covers $40sh
both sideview mirrors, black with glass $45 sh ea
93 fuel rail $35 sh
93 seatbelt guides $35 sh
hardtop A pillars, dark grey $30ea + sh
power mirror corner bezels, dark grey...$35 shipped
A pillars for camaro t top dark grey color $45 shipped
A pillars for camaro hard top dark grey $55 shipped
camaro door sill plates dark grey $40 shipped
sail panels dark grey $40 ea shipped
knee bolster dark grey lt1 camaro $40 shipped
fuse panel cover (left side of dash) camaro x2 $25 shipped ea dark grey
93-97 radio bezel cover dark grey x2 $30 ea shipped
93-97 camaro headlight switch x2 $25 shipped ea
93-97 camaro a/c switch panel $25 shipped ea x2
cowl panels for camaro x2 sets $45 shipped ea pair
cargo cover both dark grey $45 shipped ea
93-02 camaro berger panel black $85 shipped
93-97 cluster bezel dark grey $60 shipped
1LE window switch covers $40 shipped
2 93-02 camaro driver side sideview mirrors $40 scratched housing, $50 shipped for other
93-97 firebird fog light delete covers blue $40 shipped
Hello,
I am wondering if you would take $80.00 shipped for an automatic pedal assembly and the dark Grey A pillars for a hardtop. Also, I am looking for a dark grey hardtop headliner if you have one, the only issue would be is that it would most likely be a bitch to ship.
Also, I live in Canada but would have the stuff shipped to 14305 (Niagara Falls NY)
THanks in advance
Dave Hounsell
THanks in advance
Dave Hounsell
