Last edit by: IB Advertising
Browse all: Electrical Guides
- Camaro and Firebird: How to Replace the Starter
Step by step instructions for do-it-yourself repairs
starter motor removal / replacement
Folks,
So, my solenoid died and I'm trying to replace my starter motor. The short version is that I'm able to get at and remove the (allegedly) two bolts holding the original starter on.
My Haynes manual says to "Remove the starter motor mounting bolts (see illustration) and remove the starter motor" :
..and here's mine..
I can't seem to get that starter to come out to save my life. The picture here shows the top bolt still attached; it's removed on my car.
Does anybody have hints, tips, tricks, etc. or know of anything that I'm missing?
Wes
..and here's mine..
Wes
Here's what alldata has...
1. Disconnect the negative battery cable.
2. Remove the starter solenoid BAT terminal nut (3) and remove the positive battery cable (2) from the starter motor.
3. Remove the engine harness terminal (4) from the starter motor.
4. Disconnect the starter motor electrical connector (1).
5. Remove the air cleaner assembly.
6. Remove the starter motor bolts and starter motor.
Not sure if this helps lol
I particularly enjoy step 12 in the Haynes book... "Installation is the reverse of removal."
Does that mean I have to throw-up all of the alcohol I drank while trying to get the original part out?
Wes
Wes
There are dowel pins also to line the starter up correctly. You will have to pry the starter away from the trans. It will be nice and tight from corrosion of metal and hundreds of heat cycles....
I had to replace mine as well. It was fairly easy..just remove the two bolts and whack it with a hard plastic tipped hammer a few times from the side. It will pop out after rocking back and forth to release the starter gear from the flywheel.
It came out. I wound up putting a crow bar behind it and pushing on the starter until it started to budge... the rest was easy.
I bought my replacement from Advance online so that I could take advantage of their "save 15% and get $50 off of a future order" offer. It came last night.
http://shop.advanceautoparts.com/web...CGRP60042_____
That unit is on this page here:
http://shop.advanceautoparts.com/web...chTerm=starter
Unfortunately, if you'll see from the gears on each one of the new starters, none of them are the same as the one on our starters. The unit I purchased, in particular, was listed as:
"ProForm High Torque Starter�Chevy�V6, S/B & B/B V8 Engines 12 V 14 Kw Motor, 11:1 Comp"
I'm like, "yeah, I have a Chevy v6 or sbc/bbc engine" which made sense considering I had told Advance that I had a 2006 Chevy Impala SS. When comparing the two, you'll see that they're not even close..
So, I talked to the folks from Advance on the phone and they told me to bring it to a local store and the local store will be able to do the exchange for something that works on my car.
Thanks for the advice guys. Hopefully I'll be able to get this buttoned back up tomorrow (it's started to rain here and I'm working on the car outside).
Wes
Wes
Maybe mine was different, but on mine the dowel pins came out with the starter vs. staying on the transmission.
The LS4 starter is quite unique in that it is a reverse rotation setup with a rather large pinion gear, so none of the cheapo mini starters will work.
Being so unique, the starter is also far from cheap. Autozone lists it for $175.99 including core charge. Rock Auto wants 227.99 + $70 core
Immediately after leaving Advance, I went two doors down to a Pep Boys where the guy pulled up the starters for our cars and they looked exactly like the one I had just returned to Advance and that he didn't have a compatible part for me, but he did know of a guy who rebuilds starters and alternators and that he could rebuild it quickly and cheaply. That guy is out of town until Monday... so, if I go there on Monday and it takes him a few days to get it done, I might be rolling a week from now.
Wes
Do u need it out ?
Do u need it out ?
Yes I'm changing the starter and one of the dowel pins stayed in the transaxle and another on the starter. Of course, the new starter has the dowel pins located in the starter.
I could reuse the old starter for now but eventually I want to get this swapped again.
EDIT: Penetrating oil and vice grips have been a no go. I even went out and purchased new needle nose vice grips and they can't get a good grip on the dowel.
U could also try drilling it on centre. They're soft inside and can be tapped once you break thru the surface. Drill it and tap to 1/4 NC or something like that and use a puller to get it out.
Also maybe leaving the oil in there over night will help loosen it.
What about removing the corresponding dowel in the new starter. Shouldn't be as tight as the one in the tranny.
The transmission has not been rebuilt. The car doesn't get used much. That same day, I replaced the air conditioning hose in the front since it leaked last year some time.
It's just that the G8 is such a much more fun car to drive really. But I do plan on getting the Grand Prix fixed.
Thanks for the suggestions!
fieroguru?
I'll try this suggestion when I get at it this weekend or the next. I just simply reused the old starter that makes the random starting noises.
Resurrecting this old thread instead of starting a new one. I just replaced the starter in my 08, original 130k. The steps to remove is simple enough, but like others have mentioned these are still stuck after removing the bolts. Hearing about crack transmission cases or broken dowel pins I already decided I wasn't going to use alot of force, patience which isn't my thing had to happen. Soaking the area with PB blaster and Kroil oil helped some. Pry bar in micro increments is what finally freed it up. Factory dowl pins were stuck, so I just removed the pins from the new unit. I used this unit from Rockauto, reviewing the specs looks like this has more cranking power, for sure the car spins faster then it ever has so it just might have more power. Only turns into a **** job once things are stuck, if yours has been replaced before it might be much easier. Glad that jobs done, on to the next.
