Comp Cams 1.7 Shaft Mount Rockers, Nextek Springs, LS2 Timing Chain
Category: Racing Parts
Price: $1
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, 04-06 Pontiac GTO
Location (State): GA
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Comp Cams 1.7 Shaft Mount Rocker Arms with spacers. Will fit LS1/6 and AFR heads. I am not sure about Trick Flows. They bolt to the stock rocker arm locations. I will include a set of Comp Cams 7.20" pushrods that work with the rocker arms + shims and LS7 lifters (Not Included). The rocker arms are fully adjustable and will help stabilize the valvetrain with high lift cams and high rpms.
$600 Shipped obo
Manley Nextek Springs 1.580 O.D. Uninstalled from a new set of heads. Never Ran.
AFR-8023 1.580 OD 235# @1.950 Premium Grade 1.170 535 730
white .832 ID 610# @1.250 Chrome Silicon
http://www.airflowresearch.com/valve_spec.php
http://www.airflowresearch.com/index.php?cPath=34_39_63
solid roller 730" lift springs
these were over kill for my cam. These springs are $280.00 new AFR
$140.00 Shipped
LS2 Timing Chain. Only has about 3K miles on it. The only reason I am selling is because I upgraded to a Rollmaster double timing chain:
$60 Shipped obo
Greg Banish Tuning DVD and two tuning books. These together are $300 new.
SOLD
Pacesetter Long Tube 1 3/4" headers. These have the ceramic coating flaking off at the bottom. I was told that this was a common problem with the early Pacesetter Headers. They are for off road use only with no provisions for the EGR.
SOLD
Fuse area dedicated Nitrous Fuel Cell. Holds about 3.5 quarts. Have the springs to run either high or low pressure. Also includes the -6an fitting for your Fuel Solenoid.
SOLD
I am located in Richmond Hill, GA.
i want these rockers bad just trying to sell a bunch of parts i don't need anymore local.so hopefully you still have them,just need to get $200 more for them.been looking at the T&D's which i think these are just made for comp cams.so bump for you
