LS1 engine parts (241 heads, lifters, cam), GTO parts, ARP studs and various C5 parts
Category: Engine - Intake/Fuel
Price: $1
Part Fits: 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO
Location (State): VA
Item Condition: Brand New
LS Engine?: Fits LS Engine
2 stock radiators - $100 each
*One removed around 100k miles from a 2001, the other came out of an '04 with 15k. Upgraded to a custom race radiator so don't need either.
Bumper cove filler close-out panels - $30/pair
K&N filter for 4" intake tube - $40
* Brand new never used, includes clamp
OEM brake ducts pre-cut for DRM cooling extensions - $10
Passenger Side Air Dam - $5
* Some wear
* Driver side sold
Nearly new LS1/6 timing cover - $50
GM HD C5 endlinks - $45
LS1/6 cam gear approx 50k miles - $15
2 OEM 192 degree LS2+ tstats - $5 each
1 OEM 192 degree LS1 t-stat - $5
160 degree SOLD
3 sets of LSX rocker arm pedestals - $10/pair
1 sold, 2 sets left.
4 sets of OEM LS1 pushrods. All roll straight on a glass table:
Brand new - $20 SOLD
Lightly used - $20
100k miles - $15
2nd set C5 front spring adjuster bolts; uncut - $30/pair
1st set C5 front spring adjuster bolts; uncut - $30/pair SOLD
1 set of rear spring adjuster bolts; uncut - $15 SOLD
C5 door accordions - $10
C5 passenger door control panel - $10
C5 passenger air bag switch - $10
C5 interior door handles - $20/pair
Spindle aka knuckles - $50/pair, $100 all SOLD
Torch red front fascia - $50 SOLD
Front bumper lower close out panels - $10 each, $20 pair SOLD
1 Motorad 160 degree LS1 t-stat - $20 SOLD
Halltech Stinger Intake - $70 SOLD
Center air dam with brackets - $30 SOLD
Radiator shroud with air temp sensor - $30 [b]SOLD]/b]
Radiator cradle - skid bars - $50 [b]SOLD]/b]
Pro Dyno C5 Pro Cold twin cone intake - $50 SOLD
Stock intake with Z06 lid and Donaldson filter - $50 SOLD
Driver side air dam - $5 SOLD
3 timing cover gaskets ALL SOLD
Upper and lower radiator hoses - $20 each, $40 pairSOLD
Hood shocks - $15 SOLD
Upper radiator support mount bracket - $30 SOLD
LS6 exhaust manifolds with AIR port block-offs - $75 SOLD
LS6 oil pan with windage tray and pickup. Needs a thorough cleaning - $150 SOLD
OEM valve covers from a 2001 LS6 (includes oil fill/cap, bolts, gaskets) - $100 SOLD
New LS1 springs. Never run - $20 SOLD
LS6 valley cover from a 2001 - $50 SOLD
2004 Sachs Z06 shocks with Hardbar delrin upper mounts - SOLD
Delrin front spring adjuster bolts - $30 SOLD
C5 Z06 springs - $250 SOLD
C5 engine mount pedestals - $50 SOLD
New LS1 cam from 2004 GTO crate motor. Never run - $50 SOLD
OEM LS1/LS6/LS2 rocker arms with bolts. 100k miles. No issues or odd wear - $20 SOLD
New 241 heads with springs. Never run - SOLD
New LS2 timing chain. Never run - $20 SOLD
Brand new LS2 lifter trays - $20 SOLD
New 2004-spec LS1/6 valley cover - $50 SOLD
Stock LS plug wire shields - $10/set SOLD
OEM LS serpentine tensioner - $15 SOLD
Stock C5 shifter - $5 SOLD
ARP head stud kit for pre-2004 LS1 - $250 SOLD
New LS6 exhaust gaskets - $15 SOLD
New LS1 lifters. Never run - $20 SOLD
2 new LS1 GTO oil pans with pickup tubes and gaskets. Never run - $100 each SOLD
1 C5 Z06 wheel center cap - $5 SOLD
LS1 GTO/Fbody balancer. Never run - $50 SOLD
C5 cup holder insert - $5 SOLD
OEM LS1/6/2 oil cap - $5 SOLD
OEM LS1/6 starter. 100k miles. No issues when removed - $20 SOLD
OEM LS1/6/2 rocker arms with bolts. Low miles - $40 SOLD
