any factory oil pans fit 1st gen camaro ls swap?
The truck pan fits but hangs way below the cross member.
The H3 pan (hot rod pan) fits but hangs below the cross member by about 1.5"
The modified F-body pan fits
If you want to go unmodified then aftermarket pan is a must. I used the Holley pan on my swap.
Save yourself some time and get a pan that fits correctly. I had a CTS-V pan, it only hung 1" below the crossmember.. I bottomed it out and cracked it. Get one of the Swap pans. If Cast, get the Holley 302-2 or MAST pan. most of the Steel once will be ok.
You can still a un-modified F-Body pan in.. but it get really close to the steering linkage and you have to push the engine back a lot.. that will cause Firewall and Trans Tunnel fitment issues. If your going F-Body.. get S&P to notch it.
Just my opinion..
BC
Just my own 2 cents worth.
Just my opinion..
BC
Good advice...S&P notched my f body pan...nice work. My swap already had the H3 pan in it and the stock fbody pan hit the crossmember so.....I notched the pan.
Being 7.5" deep in the rear sump. It is not very well suited to many of these Pro Turing, lowered type of Swap many are doing. Even for standard height suspension swap.. it is very questionable for being safe as far as ground clearance. When I cracked my CTS-V pan (6.75" deep) and ended up on the flatbed.. I bottomed out just getting on the freeway ramp.. which leads me to have an opinion on pans that hang below the cross member.
BC
The Holley 302-2 pan is $350 from Jegs or Summit. Steep price, but it clears everything, doesn't require any notching, and doesn't hang below the subframe.
Get the Holley pan if stock front ride height is too high for you.
Notching the crossmember on the 1st gen will help lower the engine. But doen't help with the linkage. It will help on a front steer car... Abody or 2nd gen fbody.
let us know what you notch looks like and whatyou did for the steering linkage.
BC
BC
Here's my frame notch, we are mocking the LS3/6speed up soon, when I get to the steering issues if any come up, I'll post up what I do to remedy it.
EDIT, I remember why I wont have issues, I'm doing 3rd gen F-body steering which uses a longer pitman arm. Sorry, so much going on with the car I forget what the hell is going on sometimes haha!
CTSV pan works also and does hang less than an inch. I posted pics on one of my threads. Here's how you ensure a pan that hangs will not get hit. If I used the V pan, I was going to get a thick piece of angle iron and weld it to the bottom of the crossmember. Just let it hang enough to hit the metal and not the pan. I'd rather it hit the angle iron than my pan.
EDIT, I remember why I wont have issues, I'm doing 3rd gen steering which uses a longer pitman arm. Sorry, so much going on with the car I forget what the hell is going on sometimes haha!
