Turbo Accessories, AN Fittings, Exhaust parts & much more! Priced to move!!!!
From: Central Indiana Honors: 4th grade spelling bee contestant
Category: Engine - Power Adders
Price: $0
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): IN
Item Condition: Used
LS Engine?: Fits LS Engine
B) The parts to attach a transmission cooler to the radiator. Came out of the transmission cooler I purchased. Brand-new in package. $2.00
C) Summit Racing exhaust hanger #SUM-630550. Brand-new in package. $3.00
D) Plug wire numbering set. $2.00
E) Brakelight switch. New never used. I put it on my car, but swapped it before ever wiring it up. $5.00
F) Help Brand #13808 Stop Light Switch Retainers. New unopened package. $1.00
G) Zurn Qest Coupling. 3/8" to 1/2" (actually for Pex tubing) $2.00 for both.
H) - SOLD
I) Dayco Poly Rib Belt #5060525. Brand new. $5.00
J) Belt #6PK1295 %10K6. Brand unknown, but brand new. $5.00
K) 3-bolt 3" Exhaust Flanges with gaskets. Brand new. $10.00
L) - SOLD
M) - SOLD
N) Hose Coupler 3" long, 3" I.D. Brand Unknown. New in package $2.00
O) Turbonetics #30172-4 Hose Coupler 3" long, 2 1/2" I.D. New in package. $2.00
P) Jegs 1 1/2" Coolant Hose Connector #511171. Aluminum 3" long. $5.00 for both.
Q) Factory axle studs. Used. $5.00
R) Electrical Terminal Block. Used. $2.00
S) - SOLD
T) - SOLD
U) Mr. Gasket Ultra-Seal Header Collector Gaskets #5980. Brand-new though packaging opened. $3.00
V) - SOLD
W) LS oil cap with breather attached to the top. Used. $5.00
X) Vibrant Performance V-Band Clamp for 1 1/2" tubing. Brand-new in package. $20.00
Y) Air Breather 3" Diameter 2 1/2" tall. Used. $2.00
Z) Shifter cable from Huster Quarter-Stick Shifter. Brand-new $5.00
1) Miscellaneous brackets from the Hurst Quarter-Stick Shifter $1.00
2) Speedway Motors LS1 Oil Pan Oil Temp Adapter #481-201 (low oil level plug 1/8 npt sensor). Brand-new in package. $5.00
3) - SOLD
4) Dayco Flex Hose #81091. 19 1/2" long, 1 1/4" & 1 1/2" openings. Brand-new $5.00
5) Engine Bay Fuse Block Cover from '95 Firebird. Used - painted black. $5.00
6) Astro Pneumatic Tool Company Double Offset Flare Nut Wrench Set 6pt and 12 pt Metric. Brand-new in box. $10.00
7) - SOLD
8) LPW Diff Girdle Hardware. Everything to attach the rod ends to the tubing provided in the LPW kit. $5.00
9) HVAC Control Panel. Used but works just fine. PUrchased while chasing HVAC gremlins in my '99 Silverado, but did not need. $5.00
10) QA1 Rod Ends, G Series, Stainless Steel, 1/2 in. Bore, Male 1/2-20 RH Thread. Brand-new in package. $10.00 for both.
11) ACDelco #8629526 TH400 Fluid Pipe Transmission Pan Filter Extension for deeper oil pan. New in package. $2.00
12) Turbonetics 2 1/2" Turbocharger Weld Flange, Downpipe Flange Type, Stainless Steel #30231. New in package. $5.00
13) Hood Bump Stops. Used - removed from '95 Firebird. $2.00
14) 2 Momentary Switches $2.00
15) Used Factory Plug Wires $5.00
16) - SOLD
17) 2 Rod Ends 1/4" bore. $2.00
18) Block-off plate. Used - do not have the others $1.00
19) Russell #662050 3/8" NPT Pipe Plug. Brand-new in package. $2.00
20) Earl's #993205ERL 1/2" NPT Pipe Plug. Brand-new in package. $2.00
21) - SOLD
22) Russell #663000 Straight Pipe 1/8" to 7/32" tube. Brand-new in package. $5.00
23) - SOLD
24) - SOLD
25) - SOLD
26) - SOLD
27) - SOLD
28) 10an Jam Nut. Out of package, but never used. $2.00
29) - SOLD
30) 6an Earls Shut-off Valve. Used. $5.00
31) - SOLD
32) - SOLD
33) AN Fittings Grab Bag $10.00
Contact me with what you're interested in, and I will figure out your shipping total. I am using USPS Flat Rate Packages.
PayPal accepted.
Scott
