Firebird Headlights--ALL COMMENTS/QUESTIONS REGARDING HEADLIGHTS GO IN HERE
The headlights on the Trans Am/Formula/Firebird measures amperage (resistence) to know when the headlight is fully up and fully down (controlled by the BCM). When a plastic gear in the headlight motor gets stripped, the system keeps powering the motors and thats why you hear a jackhammer/grinding type noise coming from the stripped headlight motor when you lock/unlock the doors or when you turn on/off the headlights.
There are two options to solve the problem.The gear in the OEM motor only uses half of a side to raise/lower the lights, so you have another half of the gear that has never been used.The first fix is the 180 temp fix, this is when you rotate the gear in the motor to the unused portion. The second is to replace the plastic gear that has worn out with an aluminum gear.
Heres a step by step write up for the "TEMP FIX" on that same page you can order the aluminum gear to replace the plastic stock ones.
I have used the aluminum gear mentioned above and I also have used this kit. This kit is very well thought out, it includes shims, a t-brace, rubber insert/bumper, all in order to prevent any binding/flexing that can make the new aluminum/brass gear fail.
If your little white stopper has fallen off or missing a chunk of it don't panic. All you need to do is grab a roll of electrical tape and just put enough wraps/turns of tape on the end were the stopper is or was. Works perfect!! Signs of a missing stopper is, the headlight goes fully down then pops up just a little, or it does a constant up/down/up/down
Also the harness underneath the headlight tends to develop corrosion over time, check this if you experience a dim light (bad ground), or the headlight occasionally won't go up or down or, no power to the headlight/motor at all.
If your headlights act or sound like this you have a stripped gear:
Also for those interested in upgrading the headlights themselves, check out my other thread.
https://ls1tech.com/forums/stereo-el...kit-birds.html
Any questions? Just post it up.
Hope this helps.
Dan
Has anyone notice the headlight not coming up to the same level? There is 3/8 difference in mine so I did some disassembly but couldn't find any way to adjust the stop or linkage for the up position.
http://www.cardomain.com/memberpage/482801/7 ...
The 1987-1988 Fieros use a new headlight system, which is also used in 1987 and later Firebirds.
A knowledgeable proprietor of a Firebird performance scrap yard clued me in that mid-80's (82-86) Firebird headlight motors are interchangeable with early Fiero headlight motors (84-86) with one note:
the right and left motors are switched ie. the driver's side motor on a Firebird matches the passenger side motor on a Fiero. I cannabalized the Firebird motors for their gears and they work perfectly. If you do likewise, replace both gears -- not just the broken gear -- as there are differences in gear pattern. The Firebird motors appear to be entirely interchangeable with the Fiero motors, but they need to be internally inspected and regreased to ensure they aren't subject to the same grease coagulation / broken gear problem as the Fiero motors you're replacing.
