Plugs for nitrous with e85
I have a 408 w/ 12 to 1 compression running on e85. I just switched to a different nitrous setup and will be running a progressive 300 shot. Anyone know what plugs would be best to run? I used to run BR7s with the 150 shot and tr6s on motor for daily driving around. Starts up and runs alot better on the TR6s.
Ls1tech & Truck Sponsor
You could use these. They also make a "9" heat range, but this should be enough when using it with e85 on 300.
http://www.ngk.com/product.aspx?zpid=9244
Thanks,
Garrett
