UMI Valve Cover Spacers, 3.70 gears, Walbro 255 Pumps
Category: Accessories
Price: $9999
Location (State): MN
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
All parts are located in Rochester, MN and can be picked up locally or will ship at the expense of the buyer. Payments to be made in cash or Paypal (preferably as a gift) but can be discussed.
Feel free to contact me with any questions.
Crower LS1 Stainless Steel Shaft Rockers Part #74101F. SOLD
Up for sale is a set of used Crower LS1 Stainless Steel Shaft Rockers Part #74101F. Rockers are used and currently on the engine. I am guessing they have 3000 miles. No issues with these at all.
Would need a couple of days to get pulled from the engine and will ship right away following that. I have seen these online for $1350-1500 new. Asking $1000 shipped. Buyer cover the Paypal fees. Will add photos prior to shipping when removed from the engine.
Price: SOLD
These will not clear factory valve covers. Will need a tall valve cover or to use the UMI spacers. I will be willing to sell the UMI spacers I have as well.
UMI 1999 - 2004 LS1/LS6 Aluminum Valve Cover Spacers SOLD
UMI Performance valve cover spacers give you the extra clearance needed when running shaft mounted roller rocker arms on a LS1 based engine. Valve cover spacers bolt under the factory valve cover with no modifications and raises each valve cover a ½”. This eliminates having to purchase expensive high rise valve covers. Valve cover spacers are CNC machined from 6061 aluminum and include all necessary hardware and gaskets for installation.
These were used on my engine but are in excellent shape.
Price: SOLD
Engineered Cooling Products 1998 - 2002 LS1 Camaro/Firebird Aluminum Radiator SOLD
This is an aluminum radiator for the 1998 - 2002 Camaro/Firebird with LS1 motors. It's made with proven 2-rows of 1.0" tubes that is proven to out cool 3-row and 4-row aluminum radiators by a substantial amount. Buying the wrong radiator that can't adequately cool your motor in extreme summer conditions can cost you engine damage that you'll pay for many times over the cost of the radiator. So why waste your money on a gimmick?
- All aluminum construction with a heavy duty 2-row core with 1.0" tubes.
- Heavy duty transmission cooler.
- Billet CNC machined filler neck. A new cap is included.
- Fully TIG welded construction with no epoxy.
- Upper hose and lower connection is 1-5/16".
- Overall dimensions are 28" wide x 18-7/8" tall. Core is 24-3/4" wide x 17-3/8" high.
- Does not have low coolant level sensor provisions. On 98-99 cars, you can eliminate the sensor just like the 2000-2002 cars have.
The radiators has a natural finish and for pictures, has been cleaned with scotch brite and Never Dull cleaner.
Radiator was slightly cut to allow for a charge pipe. Refer to photo.
Price: $125 plus shipping SOLD
Have have a couple of people looking into shipping costs of the radiator. I am located in 55902. I went on UPS's website and did the calculator. I used 30" x 3" x 20" as the dimensions and 22lbs. I think that would be close. This should give a good idea on shipping cost.
Fans not included with Radiator
Derale Performance High Output Dual RAD Fan and Shroud Kits 16833 SOLD
Maximum Fan CFM: 3,750 cfm
Fan Quantity: Dual
Fan Diameter (in): 12.000 in.
Height (in): 17.000 in.
Width (in): 24.000 in.
Thickness (in): 4.500 in.
Number of Blades: 5 blades
Blade Material: Plastic
Amp Draw: 18.70 amps
Price: SOLD
3.70 gears for Ford 9"
- Swapped from my car. Switched to a 3.25 gear for my turbo setup.
- Were installed new when I bought my Fab 9".
- Approximately 4-5000 miles.
- Can't remember brand for sure. Either Yukon or Motive.
- $120. Price includes shipping.
Stock Throttle Body SOLD
- Approximately 62,000 miles on them.
- SOLD
Walbro 255 intank pumps
- Have two or three used pumps (will have to verify how many I have).
- Used, but work without issues.
- Only upgraded because needed additional pump for my turbo setup.
Price: $50 shipped each.
Other Misc Parts I believe I have laying around
- 01 Trans Am ECU.
- Speartech 4L80 Harness.
- Inquire within and I can take a look and provide photos
I am located in 55902. I went on UPS's website and did the calculator. It appears it would be about $33.26 to ship. I used 30" x 3" x 20" as the dimensions and 22lbs. I think that would be close.
