Light, cheap, RWD chassis for road course?
Restricted User
I'm torn between a few choices on my next project.
I have my Nova which is an awesome street car.
I have my Vette which is going to be a big time attention grabber.
Next is either going to be a car built for the road course/autocross or a drag-only car.
If I build a car for a road course, I'm going to need a very lightweight rwd chassis that I can pick up for cheap. Not looking to spend $5k on a car just to rip it apart and replace everything. I would like race weight with me in it to be sub-2500 lbs. Car will be completely gutted. Zero interior other than shifter, wheel, seat, and pedals. Looking for something I can buy as a roller for $1500.
Everywhere I go suggests Miata or 240sx. I was trying to think outside the box a little more. I found an early 70s BMW 2002. Curb weight on them was supposedly only 2000-2100 with full interior. The guy originally wanted $1200, but now he keep second guessing and is most likely not going to sell. I found a Datsun 510, but he won't come down from $2500 and its not in the best shape. My only real problem with those is suspension and maximum tire size. I don't want to start off with something that handles really poor just because I wanted something light. I also don't want something with a junk rear end.
I've already started gathering parts for an engine, but haven't decided on trans. I'm way too cheap for a T56. If all else fails, the corvette project will get the full road racing treatment, and I'll either buy a tube chasiss roller or a 235-245" top dragster.
Restricted User
I also found this list. There is a reply with a couple of dozen good suggestions, but I'm looking for more.
https://www.reddit.com/r/cars/commen...able_rwd_cars/
Restricted User
I've been looking at the E30 and E36 a lot today.
They're both in my top 5 right now, along with a Miata, Nissan Z car (haven't decided which), and 80s celica.
The Z cars have an R200 or R230 rear, both of which can be insanely strong, and great suspension. Weight is an issue for some of them like the 300zx.
Miata is the best candidate other than the rear end.
I'm still doing research on the E30 and E36.
LS1Tech Premium Sponsor
I've always had a soft spot for the Mistubishi Starion/Chrysler Conquest. good looking, small, super light and balanced. Fair amount of engine bay room for activities as well. I had one for a little bit I was going to LS swap until family stuff happened and priorities took over :/
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Restricted User
The plan is to build a destroked 6.0 (4.8 crank) with ~13:1 pistons and LS3 heads. 1 7/8" headers with 3.5" collectors. Either LLSR or custom VVT camshaft depending on which 6.0 I find the cheapest. Long runner ITB setup based around 60mm throttle bodies. E85 and MS3-Pro.
I think I can finish the entire car for less than $10k, which will all be paid for by the 3 cars I'm building now and one I've bought to flip. My biggest hold-up will likely be transmission. I've had a ton of luck chasing down supercars at Mid-Ohio with an auto trans before, so I'm not ruling it out. It just seems impractical to spend $2500 swapping in a T56 when I can build and tune a paddle shifted 6L80e for half of that.
Restricted User
I'm swapping an RX8 to flip. They're $1500 for rollers around here and they are everywhere.
A mild cammed aluminum 5.3 RX8 with a 4L60e just sold locally for $11,000.
I plan on having it done for around $3000.
If they weren't so cheap with such a high profit to flip, I'd go ahead and strip one clean and swap it. But there just seems to be many more cheap options out there that might be better suited in the long run.
There are 3 E30 BMW rollers within an hour of me for $600 on craigslist.
They are pretty stout units. I also ran across a couple of places where people swapped in the 8.8 IRS center sections relatively easily
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
Restricted User
Time Attack LS3 Starion.
Car is beautiful!
http://www.turnology.com/features/ca...packs-a-punch/
Restricted User
