Brian tooley, lil john camshaft help
I made a thread few months back about my camshaft,
416 lsx twin 67/66, 4l80e, yank 3400stall, 10.38 comp. 6bolt genx 255 heads holley low pro intake,
My cam is custom grind solid roller 252 260 699 701 116 staight up.
I was having major issues getting he car to spool on tbrake, after adv the cam shaft 6deg i can finally get the car to leave on 8psi on tbrake, went to the track this last sat and car mustered out 9.18 @ 150mph 28psi of boost on the big end. car still very lazy down low 6000rpm up she moves. i still believe cam is way to big.. does anybody disagree?
I have tuned my own car for the last 6yrs, afr is spot on timing set at 17deg on e85... my car went 8.43 at 163 last yr with alot smaller cam and cubic inch same boost level.. do i throw this cam out and start over??
thanks guys let me know your thoughts
Should light those little turbos up no problem. I would put my money into a converter first.
Yes it will make more torque with less duration and higher DCR but the tuning window under power will get smaller.
Cal's SBF is similar in size compression and runner volume with more cam and 83/96s and it lights them up no problem.
shift extension on converter is damn near 1000rpm drop lil tight yes but hoping the extra power whould loosen that up a little,
I was hoping the car would run damn near 7s on this cubic inch and the same boost level as last yr with the smaller engine
Where is the ICL right now (as measured)? Any idea what ICL reveals peak cranking compression?
AFR doesn't really have much to do with how the converter is coupling at the track. Unless you are saying it didn't need anymore fuel compared to last year. If you added more power and the car is not picking up, I would also think there is a converter problem. Do you have any converter slip data?
Verified ignition timing? How are you identifying peak ignition timing, plugs, mph, etc?
i looked over the scan and calculated on Wallace calculator 4.1% converter slip, single disc not locked up. looked back from old tune to new tune 365 to 416 i have taken out a ton of fuel. if i new how to screen shot ve table its close to 41% less fuel
