"El Chapo" my 78 C-10 project
Old 01-17-2018, 08:01 AM
cooperhw's Avatar
Default "El Chapo" my 78 C-10 project
Been working on this C-10 project since mid March 2017. Day one, drug it out, to the tire shop for a flat repair, and home. Day two, stripped the body off the chassis so I could "chop, cut, rebuild" so it would end up much closer to Mother Earth. I bought a 2002 LS-1 hooked to a T-56 supposedly a great motor/trans. Ripped off. Opened it up one cylinder pushed out internally. Should have know when I checked the oil and fresh oil came out, not used.
Anyhow, moving on. Motor completely rebuilt and so is the T-56 (new bearings and seals anyhow). Finally got to drop it back in my pickup on Monday of this week.
Came on here today to check a few things out and figured I might as well start a thread in case any of you like pickups. Low pickups.. I have been calling my truck "Shorty" from day one, so watching a tv show on the O.G. El Chapo it stated that his nickname meant "The Shorty". Anyhow, not wanting to be super fast or anything buy I do like the added power so a B.T.R. nasty cam went in with matching springs. Had a Tick Stage 3 in my last LS and loved it. Gotta have it.
Without further ado.
Attached Thumbnails "El Chapo" my 78 C-10 project-20170425_055841.jpg   "El Chapo" my 78 C-10 project-20170521_163434.jpg   "El Chapo" my 78 C-10 project-20170529_123506.jpg   "El Chapo" my 78 C-10 project-20170819_103930.jpg   "El Chapo" my 78 C-10 project-20171105_090327.jpg
"El Chapo" my 78 C-10 project-20171105_090810.jpg   "El Chapo" my 78 C-10 project-20171110_165637.jpg
Old 01-17-2018, 08:05 AM
cooperhw's Avatar
Default "El Chapo"
More pics of motor.
Attached Thumbnails "El Chapo" my 78 C-10 project-20180114_135840.jpg   "El Chapo" my 78 C-10 project-20180114_144459.jpg   "El Chapo" my 78 C-10 project-20180115_071301.jpg   "El Chapo" my 78 C-10 project-20180115_071336.jpg   "El Chapo" my 78 C-10 project-20180115_202230.jpg
"El Chapo" my 78 C-10 project-20180115_202239.jpg   "El Chapo" my 78 C-10 project-20180115_202247.jpg
Old 01-17-2018, 08:45 AM
1964SS's Avatar
Looking low and mean! subscribed.
Old 01-17-2018, 10:36 AM
BillyFargon's Avatar
Looks awesome! Can't wait to see progress on this!
Old 01-17-2018, 04:08 PM
ten5nova's Avatar
Cool build, I’m in the process of installing a 5.3 in my 80 GMC C15 Heavy Half, are you using exhaust manifolds or headers? I plan on using manifolds and am unsure on frame clearance...
Old 01-18-2018, 08:55 AM
Alex41's Avatar
Nice build.
Pacesetter TBSS headers are a perfect fit for these trucks. They also tuck nicely at or inside the frame level; meaning they don't hang below the frame.
Old 01-18-2018, 06:49 PM
SlamItC10's Avatar
Nice build bro, I'm doing the same build now just to a 77. So I'll be tuned in!
I aslo purchased the Dingo mounts.
Did you put your engine as far forward as you can?
Old 01-18-2018, 07:06 PM
brandon6.0's Avatar
When I do a c10 swap with adjustable mounts, I measure the trans and engine mounting position. Sometimes ill use the old sbc to compare to. Doing this method allows u to install the engine sitting in the correct position as the original sbc. The original driveshaft will fit as well, and sometimes the trans crossmember fits as originally.
Old 01-18-2018, 07:17 PM
SlamItC10's Avatar
That's exactly the rout I was going to go. I was also going to measure my pinion angles this way also?
Old 01-18-2018, 08:36 PM
cooperhw's Avatar
[QUOTE=ten5nova;19812916]Cool build, I’m in the process of installing a 5.3 in my 80 GMC C15 Heavy Half, are you using exhaust manifolds or headers? I plan on using manifolds and am unsure on frame clearance...[/QUOTE
manifolds. Used em on the last two and never have had a burnt wire. they flow well.
Old 01-18-2018, 08:41 PM
Received 3,024 Likes on 2,355 Posts
Manifolds; used em on the last two and never have had a burnt wire. they flow well.
(Cooper; I hope this cleaned it up for ya a bit! )
Old 01-18-2018, 08:46 PM
cooperhw's Avatar
thanks
Originally Posted by Alex41
Nice build. thanks I appreciate it.
I think I will stick with the factory manifolds for now. even with manifolds my last ls-1 put down 359hp to the tire. very happy with the performance. exhaust cut out I open up every time I get where I'm going.
I aslo purchased the Dingo mounts. Right on. post a pic of that bad boy. love to see it. I am very happy with the Dirty Dingo mounts. used em on two so far.
Yes.
Mine is going to be at ride height at 4 inches off the pavement so I need to set my driveline angles there. gotta get it off my portable poor boy lift stands first.
Thanks Mike. Gotta get busy now
Old 05-16-2018, 03:09 PM
cooperhw's Avatar
Default Little progres
Finally got around to posting up some pics of progress. Hoping to fire it up this coming weekend.
Manifolds. Making plenty of power and with exhaust cutouts installed it will get plenty loud when i get where I am going.
Nice build.
Thanks.
might check em out after it's on the road.
Don't know why it posted the pics twice (probably me), or so huge.
Thanks.
No, I had already cut out the tunnel area so i would have plenty of room for my T-56 so i pushed it back to give me as much room for radiator and electric fans as possible.
finally getting the front end stuff put on.
cheap grill in place for now. will put my cherry factory grill on later once i have time to restore it.
I love it when you can finally land something in it's permanent resting place.
starting to look like something
cheap grill will do for now. got a cherry factory grill that will go on eventually once i have time to restore it.
Can't wait to get the halos in place.
nice azzz
Led's are gonna pop at night.
Old 05-16-2018, 03:21 PM
Looks so good.. makes me want to get a square body.. I think my life needs one
Old 05-20-2018, 03:10 AM
dec010974's Avatar
Awesome
Old 05-20-2018, 08:39 PM
Advanced Design's Avatar
Very nice! Tagging along here too.
Quick Reply: "El Chapo" my 78 C-10 project
