what window switch
what window switch
Hey guys,
so iv'e read about some people having problems with the MSD window switch. So i was wanting to know which one i should run/what you recommend.I don't need a complicated set up. 1 stage for now and car is a 02 ss ls1, ill be using a 92mm wet plate kit from nitrous outlet .
He man, long time no see I don't know if I ever told you but I have a MSD window switch and it's garbage. Been meaning to see if I can fix it, or just get a different one. So you got that kit installed now?
God knows I need a progressive delivery of some sort with my setup lol. That NOS Mini sounds interesting. Kill two birds with one stone. Kirk you may want to consider a progressive controller of some sort if you plan on doing more than a 150 down the road, or simply have traction issues like me lol
Then I’ll just go with the NOS mini then. I don’t have a LNC-2000 and o wont buy one. I’ll just use my hp tuners when I wanna swith it over to a nitrous tune. I know it’s more work than just using the LBC-2000 but I don’t wanna spend the money on one unless I need it.
Originally Posted by HCI2000SS
Was it easy to instal? No complications in conjunction with the LNC-2000?
Actually I think I may have seen that write up that 5.7 stroker did, but I should go back and read it again.
That's good about the NOS Mini being a straightforward install. I saw some posts in the past where people were having issues trying to install it.
