Trunion upgraded OEM LS1/LS6 rocker arms
  • Sold
ChrisM510 is offline
    $125
  • Location Toledo, OH, 43615, USA
Selling a set of GM OEM rocker arms for LS1/LS6 engines. These came out of a set of 243 heads that I purchased (mileage unknown, but heads were stamped as 2008 manufacture), and then I bought and installed the Summit SME-143002 trunnion upgrade kit. This kit uses the same roller bearings that the Comp Cams kit comes with, however, this kit uses much larger and thicker snap retention rings than the Comp Cams kit, which virtually eliminates the chance of a ring snapping. All arms have been cleaned and coated with WD40, then had the trunnion upgrade kit installed using the Summit upgrade tool and Permatex assembly lube (NOT assembled using wrench sockets). These arms have never been installed or ran since the upgrade - all arms show no wear on the tips or in the pushrod cups (I don't know the mileage, but these were obviously not run very long before the heads were removed). Again, these are actual OEM arms, not aftermarket reproductions. Nothing wrong with these, just decided to go a different route because of the amount of lift my build is taking me. Asking $125 + shipping to lower 48 US states and PayPal fees. PayPal only accepted, or cash if you pick up in person. Located in Toledo, OH.
Old 07-18-2018, 02:12 PM
ChrisM510's Avatar
Still available...
Old 08-02-2018, 04:37 AM
ChrisM510's Avatar
to the top
Old 08-19-2018, 10:15 AM
ChrisM510's Avatar
Still available...
Old 08-20-2018, 03:29 AM
my kis toy's Avatar
$200 shipped with no paypal fees on my end and I will take them.
Old 08-20-2018, 03:39 AM
my kis toy's Avatar
Also will these work on a lm7 truck heads 862
Old 09-11-2018, 06:40 AM
ChrisM510's Avatar
Bump it up...still available
Old 09-20-2018, 10:18 AM
lsa1967camaro's Avatar
What's the best price shipped to Ontario Canada
Old 09-20-2018, 01:39 PM
ChrisM510's Avatar
Ontario is a big province...what city? Shipping across the border isn't going to be cheap.
Old 10-05-2018, 04:06 AM
ChrisM510's Avatar
Still available, if interested...
Old 10-18-2018, 07:57 PM
Denard Gregory's Avatar
Originally Posted by ChrisM510
Selling a set of GM OEM rocker arms for LS1/LS6 engines. These came out of a set of 243 heads that I purchased (mileage unknown, but heads were stamped as 2008 manufacture), and then I bought and installed the Summit SME-143002 trunnion upgrade kit. This kit uses the same roller bearings that the Comp Cams kit comes with, however, this kit uses much larger and thicker snap retention rings than the Comp Cams kit, which virtually eliminates the chance of a ring snapping. All arms have been cleaned and coated with WD40, then had the trunnion upgrade kit installed using the Summit upgrade tool and Permatex assembly lube (NOT assembled using wrench sockets). These arms have never been installed or ran since the upgrade - all arms show no wear on the tips or in the pushrod cups (I don't know the mileage, but these were obviously not run very long before the heads were removed). Again, these are actual OEM arms, not aftermarket reproductions. Nothing wrong with these, just decided to go a different route because of the amount of lift my build is taking me. Asking $200 + shipping to lower 48 US states and PayPal fees. PayPal only accepted, or cash if you pick up in person. Located in Toledo, OH.
Still available
Old 10-18-2018, 07:58 PM
ChrisM510's Avatar
Yes, still available ..
Old 10-19-2018, 11:49 AM
gordoalf's Avatar
Are they still available?
Old 10-19-2018, 12:46 PM
Rocket arm still available do u have a number
Old 10-19-2018, 02:56 PM
ChrisM510's Avatar
Yes, they are available still - $200 + shipping to lower 48. I will cover PayPal fees.
Old 11-10-2018, 06:56 AM
John helsley's Avatar
do you still have them
Old 11-10-2018, 07:08 AM
send me email
Old 11-10-2018, 07:31 AM
ChrisM510's Avatar
PM sent
Old 12-13-2018, 09:11 AM
ChrisM510's Avatar
Price lowered...
Old 12-13-2018, 09:40 AM
DonH's Avatar
Hey Man,
will these work on a L33 799 heads? I owuld think they would... if so I will take them!!!
