Am I crazy for turning this kind of rpm? And timing?
I have a couple questions for you experienced forced induction fellas. First off, it’s a 2004 ls1 gto. I’m wondering if it’s a gen 4 rod engine? It had the 13mm bolts on the exhaust manifolds and valley cover if that makes any difference.
What I have is a 227/234 Brian tooley stage 2 cam, non turbo version. 113 lobe separation. The heads are ported 243’s, quench is about .039 and the combustion chambers were smoothed and polished. I’m running 17-18 degrees timing st 6-7psi boost right now. My afr was 10.8 so it’s a little rich. It never had knock at 27-28 degrees timing when it was n/a. So do you guys think I need to turn the timing down?
Also, I’m shifting it at 7000rpm. Am I playing with fire? Should I lower it a tad? This motor won’t be in here for a whole lot longer but I can’t blow it up betim giving it to my son and building a boost friendly 5.3
whats your take on this? Thanks in advance fellas.
Can't really say you're crazy for the rpm, but personally I'm not a fan of buzzing a street motor as it's hard on parts...namely valvesprings. Many around here do it though, but they are what I would call racecars, with no real expectation of longevity.
93. No meth right now. I’m running low boost. I won’t be putting it on e85 either because we only have one pump here in town. This isn’t a max effort car by any means. My goal is about 550-600rwhp reliably. I’m on 6lbs right now and I may not need to go any higher than 8psi. It honestly feels like at least 125 shot of nitrous. I happy with how it currently runs and it’s not even dialed in yet.
If you have stock pushrods, they are already bent. If you upgraded, spin it and enjoy. As to your last question, 200 rpm ain't nothing until it all of a sudden is. Energy goes up as the square of velocity, so at some point that last little bit makes a huge difference. With aftermarket cam and springs, at a certain point you have to worry about the stock lifters. You may not be there yet, but keep it in the back of your mind.
Mines a gen 4 SBE 6.0 . When it was N/A, I hit 7 k on the reg all the time. But, I put 3/8 pushrods in when I did the cam . Springs went in about 10k. Just wouldn’t hit 7 k anymore. Put BTR duals in, now it’s fine. Now that it’s supercharged, doesn’t really need to hit 7 k anymore. Just going thru the traps @ top of 3rd
I used to spin my 04 LS1 to 6800 every time i drove it. Man that motor was awesome. It was always just NA though.
Here's a vid with a gopro, motor sounds great at that rpm.
Well before it was boosted I was turning it 7000-7100 on the regular and I didn’t worry about it. Now that it’s got probably another 150fwhp I do worry about it. It’s likely over 500 at the tire. Before it was maybe 390-400ish. 4000lbs trapping 113mph and my injector duty cycle actually estimates it to be 430-440rwhp. So I’d rather estimate lower. If anyone cares to watch, I shifted around 6900, does it look like it was still pulling when I shifted or maybe it dropped off? My afr was 10.8 on this run. Just 6psi.
https://www.youtube.com/watch?v=QebpMH3HwVc&t=94s
runs good. What it run?
https://youtu.be/xiYeZOONbPA
And this is what prevents blower cars from being solid performers . Man I had to.
