EZ LS 2.0 Cam signal ?
This stuff is new to me. On my ignition controller there are 4 lites Power- Status- Cam- Crank.. I talked to tech support but could not get a straight answer. I know the cam and crank lights blink during cranking but should blink faster once it fires that they appear solid. My cam light will intermittently blink. All other are lit solid. Is this normal or do I have a bad connection? Thanks Lee
Is it reading the OEM cam sensor?
I had that EZ 2.0, pretty sure it blinked when running. Didn't run it long though, maybe 20 or 30 minutes of drive time, never did work right, removed system now I'm finishing up
installing the Holley System, hope you have better luck with yours than I had with mine. Their Tech Support Sucked, I tried to join the tech forum, they haven't
let anybody join in a long time. I started reading reviews on that EZ EFI 2.0 for LS and the reviews was disappointing, so I'm calling it a $1500.00 lesson.
The best thing was, it was bad out of the box, LOOONNNGGG Story later I called Summit to see if I could return it,
no, I could not return it because it has been installed. So I crammed it back in the box and put it on the shelf.
