Anyone sells k member spacers?
Is there a company or anyone that sells k member spacers for an Fbody? I’m trying to install a Holley hi rise intake on my 2000 trans am, but seems I need to lower engine to have it fit under the cowl/windshield area.
Hawks sells some spacers, but i wouldn't use too much of a spacer, get the rest of the needed clearance by notching the cowl. Seems like lowering the K-member too much would alter the suspension geometry, and cause too many other issues with bump steer and alignment, steering shaft length as well I'd imagine.
To each their own but i wouldn't go past the 1/4" spacer. Id be notching the cowl to do the rest. Either way reply with what you decide to use! good luck bud
