Abs/wheel speed sensor
Old 09-17-2022, 11:24 AM
02OnyxLs1's Avatar
Default Abs/wheel speed sensor
I have been looking everywhere for this sensor. Online shows something completelt different. Dont want to buy and it doesnt work. Anyone run into this issue?
Old 09-17-2022, 12:17 PM
01CamaroSSTx's Avatar
Received 1,892 Likes on 1,367 Posts
Try the salvage yards..
02OnyxLs1 (09-19-2022)
Old 09-19-2022, 02:21 PM
00PewterSS's Avatar
You can't purchase them new any longer. There is no drop in replacement other than used parts as mentioned above. If you want to get creative any passive sensor will work if you can get it to fit. The G-van is a similar size and design.
Likely the sensor you are finding is for 3 channel ABS.
Old 09-19-2022, 02:29 PM
02OnyxLs1's Avatar
i have asr which i understand would be a 4 channel module, could be wrong. Really looking to get rid of them lights on my dash
Old 09-19-2022, 02:39 PM
00PewterSS's Avatar
Yes you have 4 channel ABS. You can check the resistance of that sensor if you have a meter. I know that mine measured about 3k ohm. If the light is on immediately from key up then either the wiring is messed up or the sensor. If it comes on when driving then the sensor could be dirty or some other trouble with the controller.
Old 09-19-2022, 04:28 PM
02OnyxLs1's Avatar
can it be possoble for the front sensors be messed up?
Old 09-19-2022, 05:27 PM
00PewterSS's Avatar
Certainly possible, you should have the code read and then you will know which sensor or error that it has. Those are built into the wheel bearing.
02OnyxLs1 (09-20-2022)
Old 09-19-2022, 05:48 PM
99 Black Bird T/A's Avatar
Received 1,446 Likes on 1,004 Posts
Here's a source for 4 channel parts...
hawks motorsports 1998-02-camaro-firebird-wheel-speed-sensor-abs-4-channel-used
Old 09-19-2022, 09:50 PM
02OnyxLs1's Avatar
holy cow thats a pricey little fawker! Thanks for finder that, before that will happen i need to confirm that is the part tho. I also heard there electronic abs module next to the ps reservior that could be a problem. Would you know where i can get those.
Old 09-19-2022, 11:52 PM
00PewterSS's Avatar
Those sensors from Hawks are also used, likely salvage parts. You need to get your car scanned to find out what the fault is. The ABS module you can google places that repair them. They may have serviced ones in stock to exchange.
The following 2 users liked this post by 00PewterSS:
02OnyxLs1 (09-20-2022), bbond105 (09-20-2022)
Old 09-20-2022, 09:04 AM
bbond105's Avatar
Hawks is very proud of their parts.
Old 09-20-2022, 09:40 AM
Happy to provide the link. Hawk's should have those salvaged as well but you'll probably need to call and provide exact details.
Like the others mentioned probably want to scan for codes because loading the parts cannon for swapping parts will get expensive quick these days.
Old 09-20-2022, 10:24 AM
02OnyxLs1's Avatar
Appreciate the assistance from all will be giving an update on what the exact problem i find and the outcome.
Old 07-08-2024, 01:20 PM
naperws6's Avatar
So my 02 firehawk with 24k on odo after I hit a large bump on the road the dash ligh kicked on abs inop and traction control light is on I had my car scanned at my job and came up with this right rear or any speed sensor circuit fault code c0050 which is stored but before that i had disconnected my battery at home and by the time i got to work the light was off my dash. So sunday was driving went over some tracks going to cars and coffee and bam light is back on dash. Its a 4 channel found wheel rear sensor one used for $150 do you think its that or just needs be cleaned?
Old 07-09-2024, 09:24 AM
GM DR's Avatar
Have You tried RockAuto?
Old 07-09-2024, 09:34 AM
naperws6's Avatar
First spot I checked they only have 3 channel I need a 4 channel I have abs and traction control
Old 07-09-2024, 09:40 AM
GM DR's Avatar
What year is your car? Trans AM or Camaro?
Old 07-09-2024, 10:13 AM
naperws6's Avatar
2002 trans am
Old 07-09-2024, 10:38 AM
GM DR's Avatar
Great I live in Canada I will look around hear if that's ok with you?
Old 07-09-2024, 10:43 AM
GM DR's Avatar
Is that the one on the rear diff??
Quick Reply: Abs/wheel speed sensor
