ARP head bolt torque
Old Jan 21, 2023 | 06:51 PM
GEspo's Avatar
Default ARP head bolt torque
In the middle of head swap on ls7.. using ARP bolt kit.. did the recommended sequence to 80lbs.. do i check torque on these? I checked one and it was a tiny turn to 80lbs..
Old Jan 21, 2023 | 07:31 PM
ARP headbolts come with instructions. What did they say?
Old Jan 21, 2023 | 07:35 PM
GEspo's Avatar
3 steps, 25, 50, then 80 in sequence..
So the inside bolts wont be 80lbs when the last(outside) bolts are 80lbs? makes sense.. im no engineer, im a checker, double triple checker..
Old Jan 21, 2023 | 08:57 PM
GEspo's Avatar
Should also add im using a verified snap-on digi techwrench.. pretty cool you can watch the torque as you approach your number..
Old Jan 21, 2023 | 09:57 PM
jasons69chevelle's Avatar
Do the 3 steps once you get to the 80 go over the sequence at 80 until there is no movement on any fasteners. Usually takes 3-4 passes at 80 to get to no movement.
I think that’s what your asking.
I really like the ac delco inline torque wrench. Couldn’t believe how much the standard torque wrench would change depending on how you hold and apply force.
Old Jan 21, 2023 | 10:10 PM
GEspo's Avatar
Ya definitely, thats why i was wanting to check the 80 pass.. im using my left arm, pushing(started on drivers side, engine is in the car).. pas side will be right arm pulling so much different
Trying to hit the value, slowly, and in one movement (hunched over the engine), holding everything in line somewhat.. definitely see room for error
Old Jan 22, 2023 | 08:20 AM
01CamaroSSTx's Avatar
It's not uncommon to have an inner bolt or stud for that matter that needs a re-torque so just go throught the enitre sequence again after final torque to make sure they're 80 ft lbs. ARP has the torque specs on a sheet of paper that's folded up behind the fastener lube.
Old Jan 22, 2023 | 10:40 AM
SAPPER's Avatar
You should ALWAYS double check your first and second passes. As you tighten the bolts in sequence, others will loosen. So go over each bolt at least twice in sequence.
I guarantee you will see that your center 4 bolts are no to spec as you finish 7,8,9,10.
This is a big problem using OE head bolts. Initially the 22lbs-ft, then as you finish the last 4 you go back and check them all. I typically see the first 4 at about 16-18, which results in incorrect torque during TTY. Granted you can't recheck a TTY angle, but the initial torque is critical
Same as ARPs or any head bolt being tightened in sequence
And don't have 100% faith in ARP either, I've had a few break or stretch before even hitting the specified torque. Hence my favorite shirt.
Old Jan 22, 2023 | 11:26 AM
GEspo's Avatar
Gotcha.. thanks for the replies..
