Lloyd Mats Alternative?
I want to replace the floor mats and all my searching resulted in Lloyd Mats being the go-to shop. Problem is they are impossible to get a response from. I've messaged them through their website, emailed them, and called them and haven't received a response. Since they don't want my money can you guys give me some recommendations for where to get new floor mats?
LS1Tech Administrator
Received 1,631 Likes
I don't think I've ever ordered from them directly, I've bought a few sets but always gone through a distributor/vendor. Then again, that was many years ago and I'm not sure if they were even selling directly to the public back then - or maybe the price was just higher that way.
How long have you been trying to contact them? I wonder if they shut down for the holidays?
But I do get it, you can only try so many times before you're just "done" with a place. It's a really nice product though.
NC01TA (12-22-2023)
Rock Auto sells ACC and Dash Designs for pretty cheap but I'd have to guess on the color correctness and material look/feel just like with Lloyd Mats. Summit sells ACC and Lloyd Mats but same problem, it'd be a guessing game.
I've gotten a pair of Lloyd's Firebird floor mats from eBay. Check there
NC01TA (12-23-2023)
It's the holidays. They probably have a gazillion orders and are working overtime to fill them. Maybe touch base with them a week or two after the 1st.
NC01TA (12-23-2023)
Ok, I'll try again after the holiday season has calmed down. If I still can't get a hold of someone to send samples, I found mats that will work great from Hawks Motorsports. They cost more and won't have a logo but at least I know they will fit and the color will match.
I never got a response from Lloyd Mat Store but I did get a response from Afterthoughts Auto and they sent me samples. Here are what the samples look like against my carpet. I have the center console out for some other work I'm doing so I used that carpet for comparison. You can see the carpet that sits under the console is still pristine and the carpet that sits outside the console is faded. The samples look different against both. In the first picture the samples on the left are Ultimat ebony, gray, smoke, graphite, euro gray. The one in the middle is berber 2 ebony, then classic loop ebony and smoke, then velourtex ebony and smoke. The second picture I flipped them.
I ended up going with Ultimat ebony. Even though it's darker than the carpet you can't tell with the naked eye and in normal light. Yes the ebony velourtex looks like a direct match but I liked the Ultimat texture more and I'm sure the color will eventually fade.
When I got these for my '98, there was nothing in their catalog that perfectly matched the Dark Gray/Dark Pewter (code 14I) color used in this year, so I just went with universal black. This actually worked quite well as so many of the interior pieces in a Camaro are true black (switches, *****, etc.) regardless of carpet/seat/dash color, but many of those same items are gray in the Pontiacs so black might not blend in as well.
NC01TA (02-14-2024)
Yes, Lloyd's made this as well (again, 20 years ago in my case). I actually bought that separately, before the rest of the mats back then. Not sure if they still make these though.
NC01TA (02-14-2024)
RPM WS6 is correct about the holes in the mat. It's just the driver's mat, the passenger side has no holes. You can't order it with no holes and I also didn't use the retainers. The mat doesn't seem to be sliding around at all though. I got these from afterthoughtsauto.com and they sell just the trunk mat.
NC01TA (02-14-2024)
After two decades, mine still don't slide around. The backing material is very grippy and durable. Granted, I don't drive the car much, but in all these years I've never had to adjust it except when removing it for vacuuming.
NC01TA (02-14-2024)
NC01TA (02-16-2024)
NC01TA (Today)
small update: my driver's side mat ended up sliding forward over time. It was bugging me enough I wanted to think up a solution. I bought some 1/8" nylon cord and tied the mat to the chair mounts with the knot hidden under the mat so now it's not going anywhere.
NC01TA (Today)
