Terminator X Max not shifting 4l60e
I have a 2000 Z28 that I’ve converted to a Terminator X Max. Everything is ready for the tuner and dyno except the transmission. It will not shift gears. It will go into park, reverse, neutral and any fwd gear, but the ecu will not shift into 2nd or 3rd. This tells me the linkage of course is fine.
I unplugged the harness going to the transmission and verified there’s no bent prongs and verified my other connections. I have the ecu programmed for a 4l60e.
My only thought is I have a high stall converter that stalled to 5300 with the factory ecu. Could this lose converter be confusing the ecu? I have in the quick setup/startup that it’s a big stall. Kinda stuck at the moment. Any ideas?
Is the Terminator showing vehicle speed correctly? It is sees no or very low vehicle speed it will not command a shift.
I don't see how a high stall converter would affect this, other than requiring more revving to reach speed.
What is the converter's stall speed? What brand is it? What do you mean by "stalled at 5300 with the factory ECU"? Never heard of such a high stall on a street car.
The converter is an FTI 9.5” hard hit.
As far as stalled at 5300 with the factory ecu I mean that’s the rpm the converter runs to when launching the car just above idle. Yes it is a high stall for a street car but it’s not exactly a daily driver. lol
Pressure manifold is fubar....
Holley has something called "Trans Range Pos" which indicates what position it thinks the shifter is in. If it changes as you move the shifter, the Pressure Switch Manifold is fine. If not, replace it; as you already noted, you only have to drop the pan to do that.
Old Buzzard (04-26-2024)
ok. I’ll check into the “Trans Range Pos” and see what I find. I’m sure it’s something simple like that. The transmission shifted fine before this Holley conversion. The only thing I did when swapping to Holley was unplug from the factory harness and plug the new harness into the trans. So it has to be something simple. I’m a first time Holley user so it’s probably me that is the problem. 😂
"I unplugged the harness going to the transmission and verified there’s no bent prongs and verified my other connections".
Is it plugged in backwards?
Arrow on the plug has to face away from the trans.
Yes the arrow is away from the trans. I rechecked that just now.
Post the tune file and a short startup log.
Start the log before you crank the engine. A few seconds is all you need.
Files have to be zipped to post them.
I would suggest also logging a short drive where the trans should have shifted. Probably easier to log while connected to your laptop.
A super cool thing about the Holley system is that you don't have to choose what to log, it always logs EVERYTHING. (Hundred+ parameters?) You then view the log by toggling between 8 customizable groups of parameters.
You can even create custom parameters which are a math formula of other parameters. And then examine a log from years ago in a new way.
Old Buzzard (04-27-2024)
