2001 5.3 fouling driver side plugs
Old 05-11-2024, 08:06 AM
Jackchance17's Avatar
Default 2001 5.3 fouling driver side plugs
2001 5.3 truck motor swaped in 1979 z28, the driver side is running rich and fouling plugs at cruising speed. I have replaced injectors, plugs and wires, added grounds to my coil packs still same results. The maf has been deleted and I am running o2 sensors. Stock motor and it ran fine in the donor truck. I am lost any help would be great. Thank you
Old 05-11-2024, 10:59 PM
mrvedit's Avatar
Have you scanned for codes?
If you have a decent scanner, check for O2 sensor voltages, STFT and LTFT.
Or swap O2 sensors bank to bank.
I'm think a bad O2 sensor on the too-rich bank which always reports lean. The STFT and LTFT would then read high positive values.
Old 05-12-2024, 01:59 AM
Full Power's Avatar
Please describe in more detail what "grounds to coil packs" means ?
Coils are powered by full positive battery voltage from ignition switched power. COILs are "grounded" through ECM pins..
My bet is on a bad O2 sensor, wire connector TO O2 sensor, or a few broken off exhaust manifold bolts allowing extra AIR in to exhaust, screwing up trims
G Atsma (05-12-2024)
Old 05-12-2024, 03:32 PM
33willys's Avatar
O2 harness plugs are not crossed by any chance?
Quick Reply: 2001 5.3 fouling driver side plugs
