"low profile" back up light switch T56
Hello everyone,
Can someone point me in a direction were to find a low profile backup light switch for the t56, standard switch hits the transmission tunnel(Datsun 260z).
I know that there is a Ford unit with cables but i do not have a part number for that.
Can some one help?![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
I have found these:
https://www.summitracing.com/parts/mof-sw5857
https://www.summitracing.com/parts/smp-ls382
Christian
Can some one help?
I have found these:
Christian
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Be careful, switches have a different reach into the trans , as installed, even if they have the same thread. The best solution is to locally modify the tunnel for clearance. Yes a ball peen hammer and heavy strikes.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
I made a "temporary" one, it will work for now.
Cut down the housing and the terminal as well, solder two wires and some heat shrink tube around..
![](https://cimg1.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1124/20240609_104609_be9df5b36e1cea32971804ace3e1e49d6632a7d1.jpg)
![](https://cimg9.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1124/20240629_075032_5458cb284a149ca7313ab82a1dfbfceb9b11bba4.jpg)
