Looks like I have some retuning to do
The following 6 users liked this post by gametech:
ALL ULL C (06-19-2024), C5_Pete (06-11-2024), forcd ind (06-09-2024), Forcefed86 (06-11-2024), LS1Formulation (06-14-2024), and 1 others liked this post.
So of course on the first daylight test drive one of the craptastic chinesium oil feed hoses broke inside the braided stainless covering, and dumped over half my oil out of the car before I made it back to my driveway. Drove to summit and picked up an ICT Billet hose. Hopefully that clears up that issue.
Defective Xhinese hose part of a packaged "KIT" ( like ON3 ) or an individual ebay treasure ?
Think you hurt the turbo bearings ?
Ever hear of anyone running a turbo feed line pressure sensor ( Not a gauge, but a warning light )
Tee into turbo feed line, insert a normaly closed pressure switch, prominent warning light on dash, goes OUT around 15 or 20 PSI.
I saw an interesting post somewhere that had a burned feed line, blanket covered the fitting, hose, and burned thru-I don't think it was the Teflon lined hose though. The fitting used on the turbo seemed like it would introduce more heat to the line, and being covered. I realize not what happened to yours, but keeping the fittings exposed to air seems a good idea.
C5_Pete (06-14-2024)
No kidding. Space is so tight I just ordered the only aftermarket headlight assemblies available for this car because it looks like they will give me a tiny bit more room for the air filters. As is I had to trim the headlight housings and dent the tiny mushroom filters just to fit them at all. And I just heat wrapped the windshield washer fluid tank neck after a test drive today started to melt it. Not sure if that would have been a problem with the factory tank or not, but the aftermarket one could not take the heat. In other news, traffic has gotten a lot worse since the last time I had to tune a new turbo build. Could not find room to go past 6psi today. The spool is a little lazy on these twins for now, but I believe that is due to my leaving the timing pretty low until I get the fuel dialed in. Also due to breaking traction in 1st and 2nd gear as soon as boost starts to hit. The NT01s would already start spinning at the top of 1st without boost, so this will be interesting. Probably going to be weeks before I can access my neighbor's dyno, so street tuning will have to do for now.
The BallSS (06-19-2024)
I had to go out to my buddy's house outside the city and make rips at 11pm and later.
Even then I had to time it right, but at least the air is good in the evening lol.
