Wall thickness: 5.3 bored to LS1 ?
Going out to 3.898, what can I expect in terms of wall thickness? Has anyone ever measured or sonic tested one? Both thrust and lateral numbers would be spectacular, but I realize information is hard to get. Thanks.
Aluminum or iron block?? Not sure there's a wall thickness difference, but in case anyone knows for sure....
All iron 5.3 blocks can be bored to LS1 size and will end up with basically the same wall thickness as an LS1. Certain Gen 4 aluminum blocks can also be bored to LS1 size, and have the added benefit of siamesed bores. I just built one of those blocks myself. I didn't fully bore it out, there was no need, but there's a LOT of material left around the bore/sleeve. If you can find one of the really rare 4.8/5.3/6.0 designated iron blocks, I think those are around .375" wall thickness at LS1 bore size.
I'm curious as well. Seems like an iron block bored out to 5.7 would make a cool engine and decent power. Especially with the vast availability of 4.8/5.3 iron blocks out there. Should make a good, budget and robust build and wouldn't break the bank, no? Using stock internals.
strutaeng (06-11-2024)
Just a 2005 4x4 1500. I dont want crazy power. Just a smooth ride with some oomph. Ive never done any performance mods on LS engines, theres so much out there i just get stuck being indecisive with all the options.
Anyways, glad to see there are more people considering rebuilding the 5.3 into a modest 5.7 truck engine.
I wouldn't sweat it much. You can run hyper 5.7 piston clones if you want cheap. Any of the basic "stage 1" truck cams the vendors sell pretty much do the same thing. I'd look at the towing cam line with the factory converter. I wouldn't want to give up any TQ down low on a daily with oem converter.
Y2K_Frenzy (06-27-2024)
Blocks are pretty disposable at this point. I’d def. bore it as big as possible. General consensus is 3.905. Might look at 6.125 rods w the pistons to match as long as your in there. Its not that much more.
Honestly building your motor is likely counterproductive cost/time wise. Might try to source a decent JY 6.0 and press on. Machine work for me has always meant tons of down time and they don’t always get it right. Not to mention the cost.
Could also consider a 5.3 and a decent set of heads, cam, and exhaust. It will give ya roughly the same gains.
I was picking up healthy 4.8’s for $350 here at one point. Less than $1000 on cheap china turbo kit @ 6-7lbs will out pull a OEM 6.0 any day.
Lots of ways to skin a cat!
So, order 5.7 LS1 piston stock replacements, send out block for boring and get rotating assembly balanced. Reuse connecting rods. Install "stage 1"/towing cam and do some mild tuning and off you go... Everything else is reused.
My current heads and heads on the donor block are 706. I found q bare pair of 243s for 150$, im just skeptical because that seems cheap. Dont know howvto spot cracks or overheating damage, just nitrous pits.
What did you mean there? The crankshaft should not change at all (except for rebalancing), so thrust clearance is the same as any other LS engine family. I'm not following you... maybe I'm missing something? 🤔
There's a "thrust" side of the cylinder wall in any engine. On an LS, it's the sides of the cylinders that are toward the passenger side of the car. When the piston moves downward under combustion, the angle of the rod actually applies more pressure to that side of the cylinder wall. It's nice to have the cylinders a bit thicker in that direction. Laterally means the wall thickness measured 90 degrees from the thrust side, so front and back of block, and between adjacent cylinders.
