Turbo: Blanket or run NAKED ?
Old Yesterday, 12:20 PM
Full Power's Avatar
Default Turbo: Blanket or run NAKED ?
Plenty room under hood of Suburban.
Lots of air circulation.
Wrapped a bit of reflective heat shield around the Heater hoses, close to front of Passenger ex Manifold.
About 6 coats of VHT Ceramic paint on the Turbine.
Do I need to hide the Turbine under a blanket, or can I run through the streets NAKED ?
. For reference, my IAT stays very low highest logged so far is 59 degrees (F) , Last bend before throttle body is always COOL to the touch
Old Yesterday, 01:11 PM
Kfxguy's Avatar
whatever you want to do. But having a blanket over it should keep the underhood temps a little lower and not burn the paint on the hood right above it. the paint isn't going to hold up btw, especially with a blanket on it.
Old Yesterday, 02:01 PM
Forcefed86's Avatar
Always a good idea to limit under hood temps. Better for your wiring and everything under the hood. I buy cheap ones and coat it with BBQ grill paint to keep the fiberglass in. Also sheds water/oil when painted. In theory it will help keep the heat in the turbine, which will increase performance. (not that it would be noticeable IMO)
Old Yesterday, 04:17 PM
Full Power's Avatar
Originally Posted by Kfxguy
.........................and not burn the paint on the hood right above it.
..... Had not thought of that, Thanks for the warning !!
Old Yesterday, 06:47 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,135 Likes on 739 Posts
Even with my turbo blanket, the sheetmetal nearby and the hood get very warm. I would run one.
Quick Reply: Turbo: Blanket or run NAKED ?
