low oil light on
low oil light on
so brief summary of my setup:
MS4 cam, heads, fast intake and headers through TH400 trans and 3.73 gears
currently running full syn 5w-30 and next 3k oil change is in 1500 miles. currently running a might mouse catch can and then stock pcv. the other day was cruising to a car meet and had gotten on it a few times between 4K to 5K RPMs during the 15min drive. parked and let the car sit for 2hrs. when it was time to leave and within 2min the low oil light came on. fortunately i was near a gas station and pulled in and checked the dipstick which should barely any oil on there. poured 2 qts in and after checking the dipstick it was in the middle of the hashmarks. i poured a 3rd qt in for good measure and when starting the car the light went away and the car drove fine. is this normal oil consumption with the constant high RPM?
The dipstick does tend to show lower oil than when the car is cold and oil has drained back into the pan.
I'd try to repeat the experiment. I doubt you burned 2 quarts of oil in 15 minutes. Also check for leaks and is the car running hot at all? I had a failed thermostat in the middle of a road trip (it was opening but less than optimal) and as the car got hotter through the road trip I had to add oil often. What was happening is that as it got hotter it made a leak I had on the back of the intake leak more.
Do you think the catch can was more full than normal? Still I guess 2qts would’ve been a butt-load of blow-by I guess.
While you checking the catch can you should also grab a flashlight and have a peak into the intake through the throttle body to see if it looks wet in there. You said it's not burnig oil and if excessive oil was getting in there then it would most certainly make its way into the combustion chambers and through the exhaust. Does this car have cats?
Yeah if excessive oil was getting into the intake runners that thing would be smoking its *** off!
