is your BMR Extreme Anti-roll bar loud?
do you guys have the same issue? the XSB002 roll bar is super nice, but it makes constant chatter under the back of the car....i followed the directions installing and have adjusted it several times (with the suspension loaded), each time it'll quiet down for a trip or two around the block but then starts chattering again (on bumps)....i like that it's super tough, this thing is a unit, but it's really got me considering swapping it out for something else....started with a neutral setting, but i currently have the passenger side extended slightly more than the driver's side, enough that the passenger rear tire has about .25" larger fender gap between the tire.....it seems a little better but it's still going chitter chat chatter chit every time i hit a bump.....any suggestions?
