Recomended valve spring pressure roller rockers.
Have a a btr cam, trick flow 215x heads and fast 102. Looking to put roller rockers in the car for guide life and valve life. Looking at running yella terra rockers.What would you recomend for valve spring pressures? 7200rpm shift would like stability close to 8k incase of a miss shift.
Thank you
Thank you
I wouldn't run any less than a Pac 1207x. I would shim them up for a touch more seat pressure. What lifter are you running? The thing about BTR cams is they are totally designed around a stock rocker and the lobes are aggressive. They are touchy to dial in if you deviate from their recipe..
What ever you go with, I usually recommend around 180lbs seat pressure for roller rockers.
With that being said, what springs are in your heads now, we may have a drop in that requires no hardware change.
DualQuadDave (07-18-2024)
not to change the subject but with a stock cam like the 02+ LS6 and a 1.8 or 1.85 rocker what kind of seat pressure would you recommend? in the past with that cam and rockers i ran PAC 1211x beehives but i feel i lost valve train stability somewhere between 6800-7000rpm.
I would drop ion some PAC-1276X's (150lbs seat)
SLP IROC-Z (07-15-2024)
PAC-1207X-16
PAC-R435-16
PAC-S129-16
PAC-L8116-16
The following 2 users liked this post by TurboBuick6:
Che70velle (07-15-2024), DualQuadDave (07-18-2024)
The following 3 users liked this post by TurboBuick6:
The following 3 users liked this post by Che70velle:
