Hey yall I could really use some help I just put a 2000 4.8 ls in my 99 Silverado same size motor that came out an For the life of me I can't get this thing running aright PLEASE TELL ME if yall got an suggestion from the info below
You are supposed to run crank cam relearn after the motor is replaced. It allows the pcm to relearn the crank and cam reluctor count error every engines different and you are even supposed to run it after cam swap.
If you do it and it still sets a po300 time for deeper diagnostics
Worth checking I've ran into this before on a few that have had outside work come in the shop. Verify each injector connector is on the correct cylinder.
