Generation V Internal Engine 2013-20xx LT1
Comeback- Failed AFM lifter
Old 07-22-2024 | 12:24 PM
Fixxer's Avatar
Default Comeback- Failed AFM lifter
Hello,
I have a 2017 6.2 truck in the shop. Last year, the number 4 intake lifter came apart and bent the pushrod. So I did a soft AFM delete- VLOM modification and oil port blockoff with PCM tuning. I also replaced all the lifters on the right side with new OEM lifters and installed thick wall pushrods all the way around. Everything was great until 15K miles and a year later the same lifter #4 intake has failed again. This time it will move for 3 cam revolutions and then the rocker stops moving. Am i missing something here? Has anyone seen this before? What did you find? What should i check before i send this back out again?
Thanks,
Derek
Old 07-22-2024 | 01:16 PM
bthomas's Avatar
The afm lifters are pretty much crap. Even if not being activated, they are still failure prone. Post covid, The regular oem lifters aren’t much better either.
The following 2 users liked this post by bthomas:
Fixxer (07-22-2024), Max101 (09-20-2024)
Old 07-22-2024 | 02:10 PM
Fixxer's Avatar
Got the head off and found a chewed up roller. I'm guessing that the lifter collapsed and bounced around on the cam
Old 07-22-2024 | 02:26 PM
I would guess the cam is chewed(screwed) too. Teardown time....
strutaeng (07-22-2024)
Old 07-22-2024 | 08:23 PM
01WS6/tamu's Avatar
Save yourself the headache talk the customer into pitching that garbage.
Ive had your same scenario happen more than once on customer stuff too using all gm parts every last everything. DOD is just pure crap.
Quick Reply: Comeback- Failed AFM lifter
