Fast 92 install
Old 07-23-2024, 06:49 PM
Steves1911's Avatar
Default Fast 92 install
Trying to get all the bits ordered for a fast 92 install on my trans am. I will be getting a nick willams 92mm throttle body to go with it and utilizing the factory fuel rails. I know the fast doesn't come with gaskets or hardware so I'll be sure to order those with it. Where I'm getting hung up is with the coolant crossover tube. Will a 4 corner steam kit from Earls performance take care of that and fit with the fast or will I have to plug the rear and put a crossover tube on the front?
Old 07-23-2024, 08:48 PM
Rich-L79's Avatar
If you want a four corner steam vent kit, you have to get one that is specifically made to work around a FAST manifold.
Steves1911 (07-23-2024)
Old 07-23-2024, 08:50 PM
Rich-L79's Avatar
Here's a kit that is known to work.
https://www.ebay.com/itm/132107718315
Old 07-23-2024, 08:51 PM
reeves05's Avatar
I plugged the rears and done the crossover on the front. Simply cut the tube where it mounts to heads and weld/braze it shut as rear plugs.
Old 07-23-2024, 08:58 PM
reeves05's Avatar
see attached: rears are hard to see in photo but you get the idea.
Old 07-23-2024, 09:02 PM
Steves1911's Avatar
Thanks for the replies I'd rather not plug the back so I guess I'll be going with a 4 corner setup . Trying to order all these parts from one place so I guess i will be going with the motion raceworks 4 corner kit for low profile intakes .
reeves05 (07-23-2024)
Quick Reply: Fast 92 install
