LS Rebuild with low oil pressure
I recently had my 6.2ls shortblock rebuilt, but I'm only getting 10psi oil pressure (hot) at idle, and 22psi at 2000 rpm. A larger cam (about 2 steps above stock, but not large enough to require a torque converter) was part of the rebuild. My concern is that stock specs are 24psi at 1000 rpm and 35psi at 2000 rpm, yet my mechanic assures me there is nothing wrong with it. Am I safe to drive it without causing damage to the engine? I don't currently have a complete list of parts that were replaced, still waiting to get that from my mechanic.
Your "mechanic" is absolutely full of ****. No fresh built engine should be making 10psi hot. Best guess, he pinched the pickup tube O-ring and doesn't want to man up and fix the problem.
He is saying that because of the larger clearances for the new cam, he put in a "high volume oil pump" which will lubricate the engine better but create less oil pressure? I did pull off one of the valve covers and the top end appears to be getting enough oil. I'm still worried I'm going to destroy the cam bearing with such low pressure if I drive it.
You may very well be right. Job security!! Any automotive engine I've ever rebuilt.....Let's just say if it was making 10psi@idle, it would be coming right back apart, either I'd disassemble, or it would be taking itself apart before I could get it shut down. Sounds like a bad, or wrong, O-ring......
High Volume Oil Pump by design is high pressure, with volume comes pressure.
Stop driving it and find someone else, as we've said.
I'm taking it to a different mechanic to have the oil pickup tube O ring replaced and oil relief valve plugged (engine has DOD delete) as a last ditch effort to get oil pressure back without having to tear this thing apart again. I wish there was a way to get this oil pan off without dropping the differential...
