Acetone in gasoline...
Berryman's B-12 Chemtool injector cleaner is Acetone, Toluene, MethyEthylKetone, butoxyethylene and a dash of Isopropyl I figure it's about 130 octane, and only costs $20 per gallon. Might get ya couple more degrees of spark advance.
I used denatured alcohol in gas once to pass emissions and it worked to lower the HC’s.
The following 3 users liked this post by Y2K_Frenzy:
The following 2 users liked this post by Treburkulosis:
68Formula (08-30-2024), Y2K_Frenzy (09-01-2024)
I'm sure it's safe on occasion, but I'd be cautious about putting it in every tank. Acetone and methanol is pretty aggressive on steels and Methyl Ethyl Ketone on o-rings and plastics. The 2-butoxyethanol is hygroscopic like ethanol. Long term consistent use may cause damage.
LS1Tech Administrator
Received 1,806 Likes
The following 2 users liked this post by RPM WS6:
All that bureaucracy just to catch that < .00001% that might be out of compliance. Half of which those impacted probably can't even afford the repairs anyway. SMH
wannafbody (08-30-2024)
...................... tag on back sez " FLEX FUEL" We're all good.
Secondly vapor and pressure can create cavitation-induced shock waves (basically micro-bubbles bursting), which attacks surfaces of stainless steels at a micro-structure level. So if it increases the potential system vapor @ pressure over ethanol blends, it can cause long term damage. Might take several thousand miles, but it can happen.
It's at your own risk if you want to use your car as a long-term test bed. But be prepared to possibly need to replace things in the fuel system path from tank to injectors. And hopefully if it's the o-rings that let go, you catch it before the carbecue.
. ..............................WAY ahead of ya Sparky..,....................
Been buying Berryman's B-12 Chemtool- 4 gallons to the case since 2016, and running a GALLON per tank in a " Flex-Fuel " Tahoe when on the ROAD.. STILL have the OEM fuel pump, from 2002 - no ****. -- Havent had any O-Rings fall off yet--.
Ran the Tahoe down to Texas and back, the LONG way in 2017. 11,000 miles in 3 weeks. I said the LONG way, we crossed 3 Canadian provinces ( twice) and 11 states.
Also, since the best Road Fuel we can get delivered in Alaska is 90 Octane, I usually add 10 Gallons of 100LowLead avgas, and 5 gallons of ( either ) Toluene or Acetone each time I get my bulk tank filled. Apparently blends containing 2% Leaded AvGas is O2 sensor safe, because BOTH primary O2 sensors AND the AEM wideband are still working after 8 years of daily Magnuson BOOST.
wannafbody (08-31-2024)
